R56 Kw variant 2 wheel spacers
Yeah they're hitting the perch I'll check with Ecs thank you.
ECSTuning (10-09-2017)
You either need t raise the perch over the tire or uses spacers. I had this problem and refused to raise the car. I got away with 5mm spacer and I cleared by a business card with 215/40/18
mQubed Motorsport, Manic/NM Tuning Dealer
Surprisingly, this can be issue on many chassis with KW. I had the same thing on my BMW with V2s, which is an entirely different application!
+1 for the ECS spacer kit, no sense buying the wrong size.
Is this a Mini-specific issue? Not following you here.
Multiple providers sell spacers with flange/hub extenders from 10-25mm, though (even 7-8mm). I won't install spacers without that hub extender, even if they're 8mm.
