R56 Way Motor Works Hoot Heat Shiel Install Question
Old Jun 25, 2017 | 01:35 PM
cactusjk's Avatar
cactusjk
Can someone explain how to install the hood heat shield. Having trouble figuring out how the notched side slides under the scoop?
Attached Thumbnails Way Motor Works Hoot Heat Shiel Install Question-oem-r56heatshield.jpg   Way Motor Works Hoot Heat Shiel Install Question-r56-hood-heatsheild-big.jpg
Old Jun 25, 2017 | 03:34 PM
sikamini's Avatar
sikamini
I'm guessing it uses the connection points at the factory hood shield. Re: pic.
Old Jun 25, 2017 | 03:52 PM
cactusjk's Avatar
cactusjk
It does. The question is how to get the notched part up under the hood?
Old Jun 26, 2017 | 01:07 PM
NeonLed's Avatar
NeonLed
The notched part goes between the black plastic piece and the metal.
Old Jun 26, 2017 | 08:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Great pic that is how it goes.
Old Jul 2, 2017 | 02:18 PM
cactusjk's Avatar
cactusjk
Worked like a champ! Not sure if those plastic fasteners will hold. They seem pretty loose?
Old Jul 6, 2017 | 06:36 PM
cactusjk's Avatar
cactusjk
WMW says you can add a washer to tighten up the fastener. Has anyone done this?
