R56 Timing Chain replacement project
Old 06-21-2017, 07:32 PM
BRGMCouper's Avatar
BRGMCouper
BRGMCouper is offline
Hello All,
I recently had the top guide break on my '07 S, and decided to take on the project myself. I have all of the parts, but was hoping someone on here has the cam locking tool that I could either purchase, rent, or borrow. I'm in the Chicagoland area and would appreciate any help anyone can give.
Thanks,
Bryant
Old 06-21-2017, 08:09 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
We keep the tool kits in stock
https://www.waymotorworks.com/timing...7-r58-r60.html
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Old 06-22-2017, 12:53 AM
BRGMCouper's Avatar
BRGMCouper
Thank you. It would be awesome, if I could rent it from you. I'd pay you $50 to be able to use it for an hour, then ship it back to you. I definitely do not need to own this tool forever, as I don't anticipate ever buying another r56 after all the headaches I've experienced.
Old 06-22-2017, 07:57 AM
timski's Avatar
timski
timski is offline
PM sent
Old 06-23-2017, 01:19 PM
Markos's Avatar
Markos
Markos is offline
Some tips, from experience:
Puzzle the chain guides back together to check if you've got all the pieces out. I found back a piece of plastic behind the oil pump sprocket...
If you also want to replace the Vanos sprocket (unit), buy a PSA part (Peugeot/Citroen -if available in the US). Same part, quarter of the price!
Good luck!
Old 06-23-2017, 02:27 PM
bugeye1031's Avatar
bugeye1031
bugeye1031 is offline
Moderator
Good luck!
Markos- Do you have a PSA part number for the Vanos?
Old 06-27-2017, 02:13 PM
Markos's Avatar
Markos
Markos is offline
From a German Mini Forum (I did not verify it btw):
0805.H5, succeeded by 0805.K1.
Source: http://www.mini2.info/forum/showthread.php?t=98252
