R56 A brief test drive today, happy!
Old Jun 11, 2017 | 06:06 PM
sikamini's Avatar
sikamini
So far so good! A bit of repair work done. The JCW turbo got rebuilt and upgraded with some K04 parts and polished, exhaust manifold polished, a Wagner Tuning intercooler, an Alta inlet tube, WMW turbo resonator delete, a WMW noise maker delete, a WMW turbo blanket, a new aluminum water pump, and water hose. Both intake and exhaust ports cleaned and intake manifold throttle body cleaned. She was spirited before at around 2800 rpm:s and up. Now perhaps a bit earlier and seems to have a second wind after 5000 rpm:s. The HP gauge indicates we went over 200HP at some point. Got to highway speed pretty quick.
Old Jun 11, 2017 | 06:07 PM
sikamini's Avatar
sikamini
Under the bonnet!
Old Jun 11, 2017 | 06:32 PM
pizzaman09's Avatar
pizzaman09
Nice!
Is your car originally a JCW? It sure looks like it is, I am just wondering if you upgraded to the JCW turbo or if you started with one and continue to upgrade the rest of the intake system.
Old Jun 11, 2017 | 07:05 PM
sikamini's Avatar
sikamini
Originally Posted by pizzaman09
Nice!
Yes, it is an original JCW. I sent the original JCW turbo to be upgraded and rebuilt after it had a mishap with a loose inlet tube rubber gasket. The inlet tube I decided to switch from the original to the aluminum Alta after this second failure of a factory inlet tube. The first cracked at the turbo and the second lost its gasket into the turbo.
Old Jun 12, 2017 | 05:57 PM
pizzaman09's Avatar
pizzaman09
Oh dear that sounds like a bit of a problem set with your intakes.
Old Jun 12, 2017 | 09:54 PM
sikamini's Avatar
sikamini
It all came out good! Now I have 2009 JCW Plus!
Old Jun 13, 2017 | 04:14 AM
sikamini's Avatar
sikamini
I left out that I also replaced the turbo feed line. I didn't want to risk a new turbo with a possibly contaminated old line. Plus I heat shielded it.
