R56 2007 Justa - Tail Light Is a Booger (top)
And it's fixed! Simple, must say it is much easier to change the bulbs in the tail light by removing the whole lens!
Basically one of the pigtails that makes contact with the metal board inside the lens was so bent it was not even able to recess into the less. It carved up the lens back plate pretty good but with some needle nose pliers and gentle tugs all is well in the world of light!
Thanks,
2tallcurtis
Thanks,
2tallcurtis
Go to the edit tab at the bottom of your post and then select delete post and also make sure the delete post radio button is also selected.
