in search for the elusive fuse diagram under the hood
i bought my Mini on May 21st and i went right to learning as much as i could about it. i browsed these forums and come across several threads on the fuses. so, went out and looked at mine and found that i was missing 2x 50 amp fuses under the hood. one went to the engine cooling fan (FL9) ahe one with the engine with a bolt of electricity through it (FL7).
i put 2 new fuses in and noticed the cooling fan come on and it is fairly loud. i have no idea what the FL7 does. i found a couple of posts that had a legend for what fuses does what, but did not match, like someone said FL7 feeds to the ignition, well my ignition works just fine with the button. https://cimg4.ibsrv.net/gimg/www.nor...d47bd66908.jpg |
This is from another post, which was for 1st gen MINI's, but may be helpful.
MINI Fuses / Relays / Earth Points Engine compartment fusebox F1 5A Digital engine electronics control unit F2 20A Digital engine electronics control unit/Ignition coil/Cylinder 1-4 fuel injection valves/Crankshaft position sensor (From K6300 87) F3 15A Camshaft position sensor/O2 sensor before cat/O2 sensor after cat/Solenoid valve, fuel tank ventilation/Relay K19 control power (From K6300 87) F4 15A Tank Leakage diagnosis pump F5 5A Relay, engine cooling electric fan (From K6300 87) F6 30A ABS/ASC/DSC control module F7 30A Magnetic clutch for AC compressor via relay K19 F8 30A control power K69923 Relay, electric power steering pump cooling fan/Switch unit Heating & A/C blower F9 20A BC1 (X11177 2) unit via I01136 and I01137 (Relay front wiper motor fast/slow and Relay front wiper motor on/off) F10 15A BC1/Left fog/Right fog/Switch panel via K47 FL1 50A Feed to F14, F31, F32 (BC1,Heating & Air con blower) FL2 50A Feed to F1, F2, F3, F4, F19, F20, F21, F22, F23, F24, F25, F26, F27, F28, F37 (BC1, steering angle sensor, clock, instrument cluster, navigation, on-board monitor, wash/wipe, horn, audio system.) FL3 - FL4 100A Electric Steering control unit/Hydraulic pump FL5 50A Feed to F15, F16, F17 (Sunroof, aerial antenna, rear wiper) FL6 40A ABS/ASC/DSC unit FL7 50A Feed to ignition switch FL8 50A BC1 (X332 20) Headlight FL9 50A DME unit and Switching unit 2-speed blower via I01135 (Relay electric engine cooling fan) FL10 50A K416, Relay heated front screen FL11 50A Switch unit, 2-speed blower heating & air con FL12 50A BC1 (X332 17) Headlight (Note: Sometimes 'F0' fuses below are labeled 'F' only in Eng. Comp. Fusebox) F01 5A Engine Control Module (ECM), Convertible top control Module F02 20A ECM, ignition coil, fuel injectors, crank position sensor F03 15A Engine control F04 15A Engine control F05 5A Engine cooling fan F06 30A ABS/ASC/DSC F07 30A Air Con compressor F08 30A Heating A/C blower, EHPS cooling fan F09 20A Windscreen wipers F010 15A Parking lights Passenger compartment fusebox F1 30A BC1 (X332 3) power windows LH F2 5A Steering angle sensor F3 5A Digital clock/Outside mirror fold-in control unit F4 5A BC1 (X254 27) Constant power F5 5A Control module for instrument cluster/Diode (From Electronic immoblizer control unit) F6 5A Brake light switch/Clutch switch module/Electronic immobilizer control unit EWS F7 5A BC1 (X254 36)/Rain sensor F8 5A Turn indicator/low beam switch F9 5A Control module for instrument cluster F10 5A Navigation computer/On-board monitor control unit/Radio control unit F11 5A K119, Relay, rear washer pump/K5 Relay, front washer pump F12 20A Ignition switch to heated seats F13 5A Reversing light switch/CVT switch F14 10A BC1 (X332 14) Constant power to interior/reading lamps F15 20A Sunroof module control unit F16 30A BC1/Rear window w/o antenna or Wave trap 1 w/ rear window antenna via K13/ Heated rear screen F17 15A BC1 (X254 43)/Rear window wiper motor via I01142 (Relay rear wiper motor) F18 5A Hall sensor driver & passenger buckle/Multiple restraint system (SRS system) F19 30A BC1 (X332 7) power windows RH F20 20A K96, Fuel pump relay 1 F21 10A Control module for instrument cluster F22 15A On board monitor control unit/Navigation computer/Eject box F23 20A K5 Relay front washer pump/K119 relay rear washer pump F24 5A Electronic immobilizer control unit/Horn for antitheft alarm system EWS F25 30A Headlight washer pump via K6 F26 10A Automatic transmission F27 15A Radio control unit/CD Changer/Amplifier F28 15A Volute spring/Right horn/Left horn via K2 F29 5A Heating and AC control module/Sensor interior temperature fan F30 5A Instrument cluster F31 30A BC1 via K4 (X253 23) Heating & A/C blower F32 15A Front cigar lighter via I01151 (Relay cigarette lighter front) F33 10A ABS/ASC/DSC unit F34 10A Digital engine electronics control unit direct and via K96/Eng management main relay F35 5A Mirror adjustment switch/Electrochrome rear view mirror/Windscreen washer jet heater/Outside mirrors F36 5A K416, Relay Heated front screen F37 20A BC1 (X332 1) Central locking F38 - F39 5A Alternator/Electric Steering control unit/hydraulic pump F40 5A Control module for instrument panel/Switch panel/Steering angle sensor F41 5A Park distance control unit/power to K69923, Relay fan steering control module/pump F42 - MCS Only - Luggage compartment fusebox (M.Cooper / M.One direct battery feed) F100 250A Feed to FL1, FL2, FL4, FL5, FL6, FL7, FL8, FL9, FL10, FL11, FL12, F1, F6, F7, F8, F9, F10, K6300 For Ref. BC1 (Body Control Unit) Located behind kick panel - drivers footwell (UK) / passengers footwell (USA / Europe) 4 Connectors:- X332 20 pin (green) X253 54 pin (black) X254 54 pin (natural) X255 54 pin (blue) IDs for Relays / Location K42 Horn relay / Behind Passenger compartment fusebox K4 Heater-blower relay (up to March 2003) / Engine compartment fusebox K4 Heater-blower relay (from March 2003) / Passenger compartment fusebox Control: BC1 (X253 23) Switch: M30/A11 K5 Relay washer pump front / Behind passenger compartment fuse panel K6 Relay Headlight washer / Passenger compartment fusebox K13 Relay rear window defroster / Behind Passenger compartment fuse panel Control: BC1 (X254 22) Switch: Rear window defroster K19 Relay AC Compressor / Engine compartment fusebox K47 Front fog light relay / Engine compartment fusebox Control: BC1 (X254 40) Switch: Left fog light/Right fog light/Switch panel light K96 Fuel pump relay / Passenger compartment fusebox Control: A6000 (X60004 24) Switch: M2 K104 Relay auxiliary water pump K119 Relay washer pump rear / Behind passenger compartment fuse panel K416 Relay heated windshield K6300 DME Main Relay / Engine compartment fusebox control: A6000 (X60004 16) Switch: F02/F03/F04/F05 K69923 Relay EHPS fan power steering / Behind passenger compartment fuse panel I01135 Relay Engine cooling fan stage 2 (from March 2003) / Engine compartment fusebox I01136 Relay front wiper fast/slow / Engine compartment fusebox I01137 Relay front wiper on/off / Engine compartment fusebox I01142 Relay rear wiper / Behind Passenger compartment fusebox I01148 Relay Shiftlock / Passenger compartment fusebox I01151 Relay front cigarette lighter / Behind Passenger compartment fusebox I01152 Relay Engine cooling fan stage 1 / Engine compartment fusebox Body Earth Locations E1 LH rear of engine compartment E2 LH front of engine compartment E3 RH front of engine compartment E4 RH side of footwell E5 LH door sill E6 LH side of luggage compartment E7 RH side of luggage compartment E8 RH door sill E9 LH door sill E10 Behind LH rear window trim panel E11 Behind RH rear window trim panel |
i had already saw this. I'd like to find an updated legend for the image of the fuse diagram i posted.
Did you happen to find an updated legend? Mine is like this also and I've been able to find nothing. Trying to figure out why my 7.5A F7 fuse keeps blowing (yet seems to affect nothing... I don't know what it's connected to in my '08 Clubman non-S)
Originally Posted by Slapps
(Post 4443437)
https://www.newtis.info/tisv2/a/en/r...7-fuse/otucon5 https://www.newtis.info/tisv2/a/en/r...r-clu/DuxhCuK7 https://www.newtis.info/tisv2/a/en/r...ne-oil/clCPS6X |
Originally Posted by rkw
(Post 4443522)
Wiring diagram says Fuse F07 is connected to "Engine breather heater 1". Something to do with the oil system. It seems to be a heating element that is connected to an oil pressure relay.
Originally Posted by 871 MCS
(Post 4215872)
i put 2 new fuses in and noticed the cooling fan come on and it is fairly loud. i have no idea what the FL7 does. i found a couple of posts that had a legend for what fuses does what, but did not match, like someone said FL7 feeds to the ignition, well my ignition works just fine with the button. https://cimg4.ibsrv.net/gimg/www.nor...d47bd66908.jpg It is Ok without R2 and R4? |
