R56 Flush Coolant - Tips?
Old May 4, 2016 | 02:40 PM
Frixos's Avatar
Frixos
I am planning to flush the coolant in a couple of months. It'll have been 3 years by then since the last flush.
I read this article on Pelican Parts on how to flush the system:
http://www.pelicanparts.com/techarti...ing_System.htm
Do any people here have any additional tips? Ways to clean out the system maybe to ensure longevity?
Old May 4, 2016 | 05:13 PM
E36-E46-R56lifewhuuuh?'s Avatar
My tip is keep that water wetter on the shelf. I have no idea why people think they need to be adding silicates to their coolant but just don't. Bmw blue is all you need
Old May 5, 2016 | 04:45 PM
neonsteve's Avatar
neonsteve
I paid an independent MINI specialist shop to do a cooling system flush on my R55 around 55,000 miles (just a drain and fill) and within a week the thermostat housing started leaking. It had a hairline crack. I guess it was just a coincidence but I ended having to replace the housing and re-do the flush.
I would also stick to the MINI brand coolant 50/50 mix with distilled water.
Old May 5, 2016 | 07:13 PM
Gubi's Avatar
Gubi
The BMW coolant is a HOAT coolant which is good for five years or 150K miles. So you're probably just wasting time and money by changing it now: this isn't like the old conventional coolants that only lasted two years.
If you've always been using the proper coolant and distilled water and you haven't had any failures like a head gasket dumping oil into the coolant there's no need to clean anything out. Just drain the old stuff and refill/bleed with new. Easy peasy.
playastarkz123
Jul 14, 2016 06:03 PM
genik
May 26, 2016 04:27 PM
BbyDenns
May 17, 2016 05:23 AM
jpwins
May 7, 2016 07:12 PM
sawdustman
May 3, 2016 05:58 PM
