Coolant leak R56 New Owner
#27
All listed here:
https://www.ecstuning.com/Search/SiteSearch/11517648827/
11517648827 is the newest part number , older part number was 11517550484 . The older ones that are not metal housing are black with that plastic.
All the housing are metal now from aftermarket to Genuine MINI.
The newest FEBI version has a Metal impeller also, the other ones are a composite impeller.
Hope that helps.
Hope that helps.
Just an update the Febi version is for now composite impeller until they update. The GRAF one has been updated and now has a new design and metal impeller.
GRAF water pump below
https://www.ecstuning.com/Search/Sit...h/11517648827/
#28
The coolant can slow leak and puddle on top of the transmission. On and off when they first start to leak as its a hairline crack at first.
Great DIY here and lots of info on the locations and what to look for. I done all of these before many times.
https://www.northamericanmotoring.co...8-no-heat.html 11537534521 KT
thank you in advance!
#29
Tank if you have hairlines cracks at the bottom. Hose needs replaces if its leak at that connection or when you move it out of the way for the oil filter changes. Glad to help.
