R56 Intake Vanos solenoid, can't get the sucker off?
Old Jul 12, 2015 | 03:52 PM
Systemlord's Avatar
Systemlord
All day I've spent trying to remove my intake Vanos solenoid, it feels loose, it turns left to right, it wiggles a little bit but won't come out! I would try the flat head screwdriver approach but I dont nor plan on removing the intake manifold. I'm sore from wiggling at it for hours taking breaks here and there, never heard anyone have this much trouble removing a intake Vanos solenoid.
Old Jul 12, 2015 | 04:32 PM
SPRINTCARS's Avatar
SPRINTCARS
Yup, take the intake off.
Old Jul 12, 2015 | 04:40 PM
Systemlord's Avatar
Systemlord
Can I get by without a torque wrench?
Old Jul 12, 2015 | 05:28 PM
SPRINTCARS's Avatar
SPRINTCARS
Yea
Old Jul 12, 2015 | 09:22 PM
Systemlord's Avatar
Systemlord
Yea
Thank you SPRINTCARS, I finely got if off, it took quite a bit of prying behind the metal plate that has the hole for the 10 mm bolt. I can't believe how clean it is, especially the metal screen. A credit to BG EPR Engine Performance Restoration PN 109, I made a thread about it and no replies. Oh well, shoulder shrug.
Attached Thumbnails Intake Vanos solenoid, can't get the sucker off?-20150712_202410.jpg
Old Jul 12, 2015 | 09:26 PM
SPRINTCARS's Avatar
SPRINTCARS
That's an old one. Debri can get into the spring area and cause codes. New ones have screens covering the springs. I grab mine with channel locks. Tape wrapped around the teeth. Then use a screwdriver and pry between the head and the channel locks.
Old Jul 14, 2015 | 05:34 AM
+1 the newest part number has the screen. 11368610388
http://www.ecstuning.com/Search/SiteSearch/11368610388/ES2715070/
Old vs new.
Old Jul 14, 2015 | 06:25 AM
SPRINTCARS's Avatar
SPRINTCARS
Old vs new.
That's the one ya need right there.
Old Jul 16, 2015 | 01:06 AM
Systemlord's Avatar
Systemlord
Do Vanos solenoids while completely functional and zero codes lose performance do to wear & tear when you have high mileage on them? I can't compare them to anything since I never owned a car with any type of adjustable cams, I had a vacuum operated EGR Valve.
Old Jul 20, 2015 | 09:46 PM
renchjeep's Avatar
renchjeep
Well, a neighbor lady of mine has a Honda Element, 2005. Over 110k. She changes her oil very infrequently, and as a result, her VANOS solenoid screen became clogged, causing all sorts of driveability concerns and codes, to the point where the car quit running. I could have cleaned the screen, but decided to replace the solenoid after a good oil and filter change. Running just fine almost 2 years later. But...I wonder if she is now keeping up on her oil changes. I am just saying....change your dang oil and filter at least every 5k. Cheap insurance.
Old Jul 21, 2015 | 12:38 AM
SPRINTCARS's Avatar
SPRINTCARS
No
elverado
Jan 18, 2022 02:51 AM
Camden90240
Sep 28, 2020 12:09 PM
67morris
May 7, 2016 11:52 AM
Sep 11, 2015 11:09 AM
HogWldFLTR
Sep 8, 2015 05:25 AM
