Mini/MINI BUILDS Showcase your Build Talents.
Tigger 2.0
Old 10-18-2014, 09:15 PM
Porthos's Avatar
Porthos
Porthos is offline
I would consider getting a better bracket for your Downpipe. I speak from experience from having the Riss Racing one. The engine moves too much and it will cause that bracket to sheer off.
  #27
Old 10-19-2014, 07:54 AM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
Thanks for the tip. I'll keep an eye on it. I remember thinking when I got the WMW DP that the bracket looked a bit anemic compared to the factory one. But I liked how much thicker the flange was. Hopefully it doesn't give me any problems. Probably should have beefed it up before getting it ceramic coated.
  #28
Old 10-19-2014, 12:27 PM
Agbullet25's Avatar
Agbullet25
Agbullet25 is offline
Is the bracket still a concern if you run a stiffer rear mount to limit the amount of "rocking" the engine does under acceleration?
  #29
Old 10-19-2014, 12:51 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
I would think it would be less of a concern. When I had the custom exhaust installed I had an 8" flex pipe installed instead of a 6" to allow more flex in the exhaust where the DP attaches. I also have the yellow Powerflex engine mount. It's a little more flexible than the purple one but in an automatic you really don't want too rigid of a mount as it will transmit too much vibration when the car is in drive and you are stopped.
  #30
Old 10-19-2014, 01:50 PM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
I have found that the motor amount, does create less stress on the DP and exhaust on manual's, but the automatics will have vibrations at stoplights. I assume it's because the torque convert is still loaded and pushing the car forward
I love the motor mount in my GP2, but hated it in my friends built hybrid S automatic
  #31
Old 10-21-2014, 01:13 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
More shiney stuff for salty
Since the engine is going to be out I figured I might as well change all the rubber coolant and boost hoses. Picked these up from Way Motor Works.
Coolant hoses.
Boost tubes.
Next up...turbo selection.
  #32
Old 10-22-2014, 08:07 AM
Centium's Avatar
Centium
Centium is offline
Following! Can't wait to see how this turns out! :D
  #33
Old 10-22-2014, 09:01 AM
N2MINI's Avatar
N2MINI
N2MINI is offline
I'm just reading along, but with a complete build like your doing I'd be upping the HP numbers you'll be happy to achieve... Plenty of 2nd Gen MINIs out there with 210-ish with just basic mods and a good tune.. Surely you'll end up with your hopes of 270. A good tune will be important to it all of course..
  #34
Old 10-25-2014, 07:50 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Can't argue there one bit. With the forged bottom end, head work and the rest of the goodies being installed on this build 300 hp should be achievable. It really comes down to whether or not I want to push it that hard. Ultimately my goal is to build a wicked quick Mini that I can still feel comfortable driving on a daily basis, take on long roads trips and not have to worry about if my wife has to drive the car ...but more about that later when we get to the tuning section.
  #35
Old 10-25-2014, 08:26 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
IIRC you went with CP 10.5:1 pistons which are alloy 2168. What are the engine warm up recommendations when using this alloy? The reason I ask is that I was reading a different thread where someone posted to not even move the car until it the engine warmed up completely to 175F. Wow, this seems extreme. I understand that you want to be gentle until fully warm but to not actually move it? I mean for me, during the winter in NC this can take 30 minutes at idle and I park indoors.
On a side note, do you know if the stock JCW/GP2 pistons are alloy 4032?
  #36
Old 10-26-2014, 12:27 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Yep that's extreme alright. For several reasons. Reason number one is water temperature has almost nothing to do with piston temperature. Pistons have very little direct contact with the cylinder walls. If they did they wouldn't be moving for long. In the cylinder, heat from combustion must propagate through the cylinder liner and block before it reaches a water jacket and raises water temp. Pistons are subjected to the same heat but are mainly cooled by the air/fuel mixture and oil so they will reach operating temperature much more quickly. I'd hate to guess how many people have burned a hole in the piston before their water temp gauge so much as twitched. The second reason that's overkill is the clearances we are talking about. 2168 pistons have a thermal expansion of 15%. If your piston to bore clearance is .002" then were talking about the time it takes an aluminum piston to expand .0003". Basically start it, wait a minute for the noise to subside and go. The downside to these pistons is you will have higher oil consumption till the piston warms and sightly faster ring wear. Even then if your clearances are correct you will still have far less oil consumption than BMW considers "Normal".
Yep 4032. Well Mahle's variant of it anyway.
  #37
Old 10-26-2014, 12:34 AM
MarioKart's Avatar
MarioKart
Vendor
How do you always have such good info, even at 3:30am?
  #38
Old 10-26-2014, 01:24 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Turbo's oh boy!
Turbo charger selection…decisions decisions. First lets look at what bolt on solutions are available for our platform along with their specifications. Then we can figure out what those specs mean to us. All flow numbers listed below are at the 70% efficiency island on their respective compressor map. Many turbos can be and are pushed past that point. It is just generally not recommend as the lower the efficiency island the more heat is being transferred into the intake charge.
FACTORY KO3 OPTIONS:
Stock Cooper S - Borg-Warner
Compressor Inducer 38mm, Compressor Exducer 50mm
Turbine Inducer 45mm, Turbine Exducer 40.5mm
Flow approx. 22 lbs/min
JCW Trubo - Borg-Warner
Compressor Inducer 40mm, Compressor Exducer 50m
Flow approx. 26 lbs/min
HYBRID KO3 OPTIONS:
JMTC S42HP
Compressor Inducer 42mm, Compressor Exducer 56mm
Flow approx. 28 lbs/min
JMTC E45HP
Compressor Inducer 45mm, Compressor Exducer 56mm
Flow approx. 30 lbs/min <Boost pressure limited by smaller KO3 turbine torque.
HYBRID KO4 OPTIONS:
Alta Hybrid - If you can find one.
Compressor Inducer 43mm, Compressor Exducer 56mm
Turbine Inducer 50mm, Turbine Exducer 42mm
FrankenTurbo F21M
Trubine Inducer 50mm, Turbine Exducer 44mm
Flow approx. 33 lbs/min
JMTC E45R
Flow approx. 35 lbs/min
JMTC GTD
Compressor Inducer 47mm, Compressor Exducer 56mm
Turbine Inducer 50mm, Turbine Exducer 44mm
Flow approx. 39 lbs/min
Owens Turbo
Compressor Inducer 44mm, Compressor Exducer 60mm
My apologies as I could find no published data on the turbine assembly nor a compressor map.
Turbo 101
A turbo charger in comprised of a compressor wheel that is attached to a turbine wheel via a shaft supported on bearings. The compressor as it's name implies is responsible for taking ambient air and compressing it creating boost. It is bolted to a shaft that is welded to the turbine wheel. The turbine wheel operates much like a water wheel in that it is turned by the exhaust gases leaving the engine. Pretty straight forward stuff so far. For the rest of this post I am going to leave off diverter valves, wastegates, waste gate controllers and complex custom installations like Garrett turbos.
As you can see ambient air is pulled into the compressor by the compressor inducer before being spun out into the compressor housing by the exducer. A larger inducer with the same size exducer will flow more air but be slightly slower to spool due to inertia. In addition a larger compressor exducer can generate a higher pressure ratio due to the higher speed of the blade tips. Too large of an exducer can also slow spool time due to inertia. On the exhaust side the exhaust gases first reach the turbine inducer generating torque on the turbine shaft before flowing through the exducer which raises shaft RPM. The same rules of inertia apply as a turbine inducer that is too large may be slow to spool and too large of a turbine exducer may fail to turn the compressor shaft at a sufficient RPM to reach target boost levels.
One way to cheat just a bit on turbines is to clip the turbine exducer. This is usually done from 5 to 15 degrees in 5 degree increments. By trimming the most curved part of the turbine blade you can increase airflow through the turbine. This is generally a good thing for the top end but can seriously hurt spool time in lower RPM's. The right way to do it is use a larger turbine wheel.
Normal turbine wheel.
Clipped turbine wheel.
In several Mini forums I have heard the same uninformed opinion regurgitated over and over. "Don't get a KO4 turbo. It will kill your bottom end responsiveness." Based on my own personal experience and data logging I have found the KO4 turbo's to spool to identical boost levels on the bottom end within 200 - 300 RPM of a KO3. Both utilize dual scroll turbine housings which increase responsiveness by separating out of phase exhaust pulses to prevent them from interfering with each other before they hit the turbine wheel and as such are very responsive. In addition the larger turbine resulted in lower exhaust temps and combined with the larger compressor it continued to produce high boost levels at high RPM long after a KO3 would have fallen flat on its face.
Ideally you want to choose a turbo that is not only quick to spool but is also capable of flowing a sufficient volume of air to meet your HP target. Generally speaking 1.1 lb/min of airflow equals 10 HP and that is BHP or shaft horse power, not power at the wheel. Generally accepted loss figures for our drivetrain are 12% for manuals and 14% for automatics.
If your looking for something with a little more kick than the JCW turbo then either the JMTC S42HP or E45HP are good choices that still use the standard KO3 turbine. If your going to step up to the next level however you'll have to choose something using the KO4 turbine. Two great choices there are the Frankenturbo F21M and the JMTC E45R. The newest revision of the F21M with 44mm exducer will result in less back pressure and lower EGT's whereas the E45R flows slightly more according to the compressor map. If however you plan on throwing everything from soup to nuts in your engine build the GT Dominator looks impressive. I personally have no experience with this turbo so hopefully someone can chime in on real world performance.
For this build I will be utilizing the JM Turbo Cooper E45R turbo charger. Attached below is a comparison photo of the E45R next to a stock Cooper S turbo. Since this unit produces 35 lbs/min of air at 70% efficiency it should be sufficient to make 275 HP at the wheels in my auto without pushing it to 65% efficiency or resorting to water/meth injection.
I thought about including a section here on reading a compressor map but there are several places where that data can be found and they probably do a much better job of it than I would. I will however recommend one very good source of information and that is the book "Turbocharging Performance Handbook" by Jeff Hartman. It is a fantastic resource containing a great deal of real world information concerning turbo selection, trim values, turbine A/R's and formulas for calculating airflow requirements, intercooler effectiveness, pressure ratios, charge density, etc.. Any performance enthusiast who plans to upgrade a turbo should own it, or beg/borrow a copy. Just don't ask for mine.
  #39
Old 10-26-2014, 01:27 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
  #40
Old 10-26-2014, 04:48 AM
cantcode86's Avatar
cantcode86
cantcode86 is offline
More great info. I've been looking for a side be side rundown of our turbo options. I agree on reading that book. Lots of great info. Between my Mini and the infancy of a turbo LS motor for my truck, I want to try to find out as much as I can.
  #41
Old 10-26-2014, 10:03 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Thanks. The only info that I'm not 100% sure on is the flow numbers on the Alta turbo as I could find no compressor map for it. Their own website says in flows 28 lbs/min whereas other sources have quoted 30lbs/min so I gave them the benefit of the doubt. Still it's an interesting comparison with the Frankenturbo since the compressors have the same general dimensions. To me it helps illustrate how much of a difference a good airfoil design and proper tolerances can make in compressor performance.
  #42
Old 10-27-2014, 03:30 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Oh forgot to mention the E45R is ported and polished on the exhaust side. This will be mated to a ported and polished exhaust manifold that is port matched to the turbo inlet. When they port the exhaust side of the turbo one of the things they do is open up the flange from 2.5" to 2.7 so I port matched my DP flange to eliminate a step in that area.
  #43
Old 11-06-2014, 01:12 PM
Gotsmanlai's Avatar
Gotsmanlai
Gotsmanlai is offline
Any update?
  #44
Old 11-06-2014, 06:40 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Should have Tigger back on the road next Friday to begin the breakin period. Also wanted to talk a little about ignition coils and plugs and how that relates to water/meth. For this build I've chosen Ignition Projects coils and Brisk silver plugs. The factory coils and NGK plugs work pretty good in our application. Adding water/meth up to an 80/20 mix also works well. Higher ratios then that however tend to result in less performance with more misfires.
During ignition a high voltage spark is created between the plug electrodes. This creates a flame kernel. If not disturbed this leads to a progressive flame front which travels outward in a controlled manner. As most know increasing boost on our platform also requires reducing the gap on the plugs. The primary reason is that the high air velocity and density present with higher boost will sometimes snuff out the flame kernel before it can propagate. Adding too much of a non combustible compound like H2O which works great at putting out fires only aggravates the situation. Since we don't want to lower boost we need to create a stronger spark and the two ways to do that is with a more powerful coil or by reducing the spark gap.
Since I'd like to try higher ratios of water/meth the coils and plugs were a must.
For the breakin tune I'll be running a custom tune based off of the factory tune to keep boost down but with two changes. The first change was to alter the secondary O2 system test as the DP has no cat. This self test is triggered periodically when the ECU is operating in closed loop mode and the engine RPM is below 3000. This self test subroutine now thinks the engine is always over 3000 rpm so it never reports an error. The second modification is to the MAP linearity table since I've refitted a JCW MAP sensor. These are 3.5 bar sensors as opposed to the standard 2.5 bar units that come on the S from the factory. Their voltage output limits are the same but the voltages generated now translate into different pressures so that table had to be altered.
  #45
Old 11-06-2014, 07:47 PM
redparchel's Avatar
redparchel
redparchel is offline
could you touch more on the specifics of determining spark gap size? I've actually had both these things (brisk silvers and IP coils) sitting on my dinning room table waiting to go into my car but I haven't been able to find a good explanation/procedure (in relation to our cars) to gap these plugs, and as spark is SUCH an important part of combustion (and a scary part with higher boost pressures) I didnt want to just 'toss em in' w/o a better understanding.
thanks for all the awesome info thus far!
  #46
Old 11-07-2014, 05:05 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
I'm not an electrical engineer but I'll gladly pass on the little I do know. Spark plug gap is really determined by three factors, engine compression ratio as it determines charge density, engine RPM and dwell time.
Dwell time is how long it takes to fully charge the coil. Since we use a single coil per cylinder it's not much of an issue. Older vehicles often used a single coil to fire eight or more cylinders which placed a huge load on the coil.
OEM's typically use larger spark gaps as it promotes a better idle and low to mid RPM efficiency but at high RPM the air inside the combustion is significantly more turbulent which again can snuff out the flame kernel but misfires will be less noticeable due to the increased RPM's. With our relatively low RPM range <7K this is not a huge issue but does have an small effect.
Charge density and compression ratio is where we run into a problem. Our dynamic compression ratio can exceed 15.5:1 and even 16.5:1 or greater. What many may not realize is that air is non conductive and acts more like an insulator as density increases making it harder for the coil discharge to bridge the electrode gap. Reducing this gap is the most simple and easy solution to implement, but not necessarily the best from a performance perspective.
In addition adding methanol to the mix adds another impediment due to its higher flashpoint. If switching to full meth performance engine builders typically recommend reducing your spark gap by an additional .005" to .010".
The IP coils quadruple the spark output, double the amperage and are multi discharge coils that fire 10 times per cycle instead of just once. If that doesn't get the fire lit I don't know what will. Iridium tipped plugs are great for longevity. Unfortunately the conductivity is not as high as traditional plug materials, but by reducing the tip diameter they can still do a very good job. The Brisk silver plugs are well...silver which has considerably higher conductivity both electrical and thermal but requires a larger electrode as it doesn't have the same hardness level as Iridium. Which means more frequent replacement. I mentioned earlier about trade offs and design philosophy. This is one of them.
I mentioned a book earlier in this thread about turbo charging and I'm going to recommend another one on performance that touches on ignition is several places. "Four Stroke Performance Tuning" by Graham Bell. Definitely worth picking up!! Some of it applies to dinosaur engines but there is still tons of great info in it we can use. I have several others that I have in my library at home. One called "Modern Engine Blueprinting" that I forgot to mention earlier, and several on engine tuning that I'll get to later on when we discuss tuning.
  #47
Old 11-07-2014, 06:05 PM
MarioKart's Avatar
MarioKart
Vendor
You always have great information, even when on vacation.
What gap are your Brisk plugs, one you get the car going 100%?
mQuebed Manic Tuning Dealer
  #48
Old 11-07-2014, 08:40 PM
redparchel's Avatar
redparchel
awesome, thanks for the follow up and loads of information!
  #49
Old 11-08-2014, 06:34 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Your welcome sir. As far as gap, my initial setting is going to be .027". That should be a good starting point. What I haven't decides on yet is which secondary knock sensor I'm going to install. Detonation on our cars should have a frequency of about 7.4 KHz and I want a secondary visual indicator to evaluate not only tuning while on the dyno and the road, but also to evaluate fuel sources as fuel quality can vary widely.
  #50
Old 11-08-2014, 07:02 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Lol, just the other day I was thumbing through "Modern Engine Blueprinting" at my Wife's bookstore. Now I'm going to have to go buy it.
Quick Reply: Tigger 2.0
