R56 My full engine built will be here.
Old Mar 12, 2015 | 10:38 PM
  #251
SPRINTCARS's Avatar
SPRINTCARS
Something needs to be smoothed out.
Old Mar 12, 2015 | 10:39 PM
  #252
SPRINTCARS's Avatar
SPRINTCARS
Yeaaaa not quite finished.
Old Mar 12, 2015 | 10:40 PM
  #253
SPRINTCARS's Avatar
SPRINTCARS
Pain in the butt to get enough in such a small hole without running.
Old Mar 12, 2015 | 10:41 PM
  #254
SPRINTCARS's Avatar
SPRINTCARS
I'll take a good look at it tomorrow and see if it worth messing with.
Old Mar 13, 2015 | 06:32 AM
  #255
SPRINTCARS's Avatar
SPRINTCARS
GOOD LORD !!! Brought the piston to top dead. Installed the head gasket. Measured how far the piston was in the hole with the gasket. It's .080 in the hole. It's good but I'm just not used to seeing it with that much space. I've always tried to send the compression thru the roof. Complete opposite in this case. Which is good. Even better thing is that they are all the same. So when the block was originally assembled they square decked the block very well from the factory.
Old Mar 13, 2015 | 10:44 AM
  #256
SPRINTCARS's Avatar
SPRINTCARS
YES !! Head is assembled. Picking it up on the way to work. Check piston clearance. Clean all the parts and assemble this project.
Old Mar 13, 2015 | 07:09 PM
  #257
SPRINTCARS's Avatar
SPRINTCARS
Should I do something to the outside of the car so only people on NAM recognize the car when I'm out cruising ? Such as a personalized tag, Sprintcars on the top of the back window Or should I stick with the bone factory stock look so it's incognito.
Old Mar 14, 2015 | 12:20 PM
  #258
Gipper's Avatar
Gipper
You think the bone factory stock look is a bully?
All joking aside, I prefer the sleeper look.
Eric
Old Mar 14, 2015 | 01:46 PM
  #259
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by Gipper
You think the bone factory stock look is a bully? All joking aside, I prefer the sleeper look. Eric
It's the surprised look on people's face when a bone stock appearing jumps up and takes off. Hehehe.
Old Mar 15, 2015 | 04:51 PM
  #260
SPRINTCARS's Avatar
SPRINTCARS
I know what I'll do, I'll get a personalized rage with one of these on it.
Old Mar 15, 2015 | 05:00 PM
  #261
cerenkov's Avatar
cerenkov
I like the first one and the last one.
Old Mar 15, 2015 | 05:18 PM
  #262
oldbrokenwind's Avatar
oldbrokenwind
This surprised look on peoples face is part of what it's all about. Stay with the "sleeper" effect at least as "sleeper" looking as a MINI can get ---
Old Mar 15, 2015 | 07:20 PM
  #263
Tigger2011's Avatar
Tigger2011
Alliance Member
+1 ^
Old Mar 19, 2015 | 09:45 AM
  #264
Tigger2011's Avatar
Tigger2011
Alliance Member
Hey Sprint,
I know you were looking at making some modifications to your HPFP, to the swash plate if I remember correctly. I think you may have mentioned at the time that you were informed Manic didn't alter FRP on the N14. Just wanted to let you know that is not the case. The FRP on the Continental pumps is adjusted on both N18 and N14 engines. I'll shoot you a PM.
Old Mar 19, 2015 | 10:35 AM
  #265
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by Tigger2011
Hey Sprint, I know you were looking at making some modifications to your HPFP, to the swash plate if I remember correctly. I think you may have mentioned at the time that you were informed Manic didn't alter FRP on the N14. Just wanted to let you know that is not the case. The FRP on the Continental pumps is adjusted on both N18 and N14 engines. I'll shoot you a PM.
Ok, sounds good
Old Mar 20, 2015 | 08:38 PM
  #266
SPRINTCARS's Avatar
SPRINTCARS
WHAT THE HELL !!! Why would you need 7 upper bearings in a 5 main bearing journal motor. DAMN IT !!
Old Mar 21, 2015 | 02:48 AM
  #267
scubbysnacks's Avatar
scubbysnacks
Sounds like you want to shoot someone!
Old Mar 21, 2015 | 03:38 AM
  #268
SPRINTCARS's Avatar
SPRINTCARS
omg God scubby, I went to the car wash. Clean all the parts. Came home, blew them off. Got the new mains. I needed 3 black bearings for the bottom and 2 green. Bottom has no holes and a groove. Then I need 5 greens for the top. I GOT, 3 blacks for the bottom and 7 green for the top. UGH !
Old Mar 21, 2015 | 04:20 PM
  #269
SPRINTCARS's Avatar
SPRINTCARS
Thinking about painting it black
Old Mar 21, 2015 | 05:11 PM
  #270
cerenkov's Avatar
cerenkov
Meanwhile, your wife is thinking, "please Lord let him get that engine out of the foyer."
I like the clean aluminum look myself. Now if the whole engine bay was blacked out that would be cool.
Old Mar 21, 2015 | 06:37 PM
  #271
SPRINTCARS's Avatar
SPRINTCARS
Originally Posted by cerenkov
Meanwhile, your wife is thinking, "please Lord let him get that engine out of the foyer." I like the clean aluminum look myself. Now if the whole engine bay was blacked out that would be cool.
LMFAO !! Your right Cerenkov. lol. It's nice that it was her idea cause she wants the car running as well. When I started it was freezing cold out.
Old Mar 23, 2015 | 03:59 AM
  #272
scubbysnacks
Attachment 107840
There's no time for painting bolt the turbo on and throw it back in the car quick!
Old Mar 23, 2015 | 05:06 AM
  #273
Tigger2011's Avatar
Tigger2011
Alliance Member
LOL...patience grasshopper.
Old Mar 23, 2015 | 06:29 AM
  #274
SPRINTCARS's Avatar
SPRINTCARS
Lol
Old Mar 23, 2015 | 08:08 PM
  #275
SPRINTCARS's Avatar
SPRINTCARS
Oil pan is on, valve cover tightened down and flywheel torqued up. I think I'm ready to start setting it in the hole.
