R56 New clutch old flywheel dont feel power?
Old Jun 17, 2014 | 10:52 AM
themarques's Avatar
themarques
Hey guys got a new clutch fitted by local garage, the flywheel was "cleaned up" so they say says they didn't skim it but polished it (I have no idea what they meant by that...probably BS). No juddering, pulls fine but when it boosts it doesn't give that kick i was used to. Reason for changing clutch was the arm cracked that held the throwout bearing.
Is it a case of the new clutch bedding in or has the flywheel been messed up?
Old Jun 18, 2014 | 07:33 PM
sgscomps's Avatar
sgscomps
If you have a gen 1 then I believe it's a single mass flywheel and can be turned. If it's a gen 2 then it has a dual mass and can't be turned and needs to be replaced if it's damaged. Most independent shops don't have the mini slave cylinder bleeding tool to bleed it right.
Old Jun 18, 2014 | 08:18 PM
Systemlord's Avatar
Systemlord
Arms in 1gen Mini's broke in half a lot, you might try the 1gen threads as you'll get the right audience. My clutch components and flywheel was replaced less than a month and a half ago, I noticed more grip/bite when shifting gears. I can feel the extra pull!
Old Jun 19, 2014 | 05:54 AM
ZippyNH's Avatar
ZippyNH
S or non-s....
S was a dual mass if still OEM...non-s was conventional...
Sounds like it might be slipping....is the motor reving faster than it accelerates?
You might want the check the intercooler boots, etc...no reason they would have touched any of that....
It might be possible the vac line to the bypass valve is not hooked up or it is stuck...would result in little or no boost!!
madmax88
Aug 21, 2017 07:07 PM
Sep 17, 2015 09:27 AM
Zettinger
Aug 25, 2015 04:04 PM
Camaro108
Aug 25, 2015 02:44 PM
Aug 25, 2015 12:58 PM
