R56 wheel fitment
Old Apr 20, 2014 | 06:29 PM
ludrof11's Avatar
ludrof11
wheel fitment
Hello all,
I know this question has probably already been asked, but I'm being lazy right now and don't feel reading through all the threads. i currently am running 16x7 et 42 with 10mm spacers. I have megan coil overs on, but not that low yet. I am looking at getting 16x8 wheels with et 25. the question is will i have any fitment issues. Currently have stock control arms and camber in rear are at 2 degrees as it sits.
Also, if you have any pictures of 16x8 et 25's on your car it would be greatly appreciated!
Thanks in advance!
Attached Thumbnails wheel fitment-rear-tag-photo.jpg   wheel fitment-stadium-3.jpg   wheel fitment-dock-photo-2.jpg
Old Apr 20, 2014 | 11:45 PM
Porthos's Avatar
Porthos
Yeah sure.
Old Mar 15, 2016 | 09:45 AM
coachvminis's Avatar
coachvminis
any answer on this? I'm looking to get 16x8 wheels as well et 25 or 30..
I'm thinking 15mm spacers should be enough for clearance..anyone?
Old Mar 15, 2016 | 02:32 PM
Originally Posted by ludrof11
Hello all,
Thanks in advance!
Nice shots of pittsburgh !
coachvminis - platy it safe with 15mm so you dont rub on the inside . Otherwise you will have to test fit with the wheels and measure out.
https://www.ecstuning.com/Mini-2007-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Wheels/Spacers/
Old Mar 15, 2016 | 08:08 PM
kelvin@pws's Avatar
kelvin@pws
You wont need spacers. The rim will not rub the inside.
What rubs will be the tire. It really depends on the model of tire and tire size (some tires are wider than others even if they both state 205), which coilover you will be using, what height you intend to ride at, and if you are adjusting camber.
For reference, I ran 17x8 ET30 on 205/40/17. Lowered on KW V1s (maxed out in the back, still more to go on the fronts.). -3.0degrees in the front and -2.5 in the back. No rubbing.
Old Mar 16, 2016 | 04:25 AM
ludrof11's Avatar
ludrof11
Thanks guys! Old post and cars out of commission now and have a countryman, but this is what I ended up with before I got in a accident. I ended up doing 16x8.5 et25
Old Apr 7, 2016 | 10:29 AM
coachvminis
Not planning on lowering at the moment. The wheels are in 16x8 et 30 what size tire is best for no rub? Would I need to go to an et 15 or et 25 for the front not to rub? Or thirdly do I need spacers to clear all?
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
Kimolaoha
Dec 5, 2020 09:32 PM
ASRman
Aug 13, 2015 09:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
