R56 Found a new intake valve cleaner...thoughts?
#51
This is the first time I have ever reviewed a product. After reading all the blogs stating that stuff like this does not work but nobody wanting to be the first to use t.ry it I decided base on the review of other CRC products. I own a 2008 mini cooper clubman s with just under 104,000 miles. My mini was running terrible and the only way to fix it was to do a walnut blast, so I thought. I followed the directions as stated on the can. Waited an hour and took the car for a spin. At first the car sputtered the first mile or two. and then the idle smoothed out and the car started running much better. After a few days the car has started to really gain back it's responsiveness, the rough idle has gone away as well as the lifter noise. All I can say is this stuff is amazing....Give it a try, you won't regret it.
#52
Think what you want bud! I will be laughing while you're spending hours to fix what took me and my son about 10 minutes. I am not one to post on blogs, or right reviews but this product worked so well for me I just wanted to pass along my experience. For the skeptics, keep doing it your way, for the ones who try this product you will be happy with the results.
#53
DIY here on how to remove and clean.
https://www.northamericanmotoring.co...-cleaning.html
#54
#55
Just remember all solvent based upper induction cleaners do result in scouring of the pistons and cylinder walls when the smaller particles of the coking brrreak loose and some are forced between the piston and cylinder wall....see this all the time when tearing down. But the results are very noticeable. No substitute for a manual valve cleaning or media blasting with crushed walnut shell.
#56
Totally correct, there's no way for you to know unless you remove the intake manifold. It takes incredible pressure and walnut shells to remove baked on oil based carbon not to be confused with gasoline based carbon deposits. If it were that easy people wouldn't pay hundreds of dollars to have their intake valves blasted by walnut media not to mention the development of creating special tools.
Even if the product did work you wouldn't be able to stop the carbon from crumbling apart uncontrollably causing damage to the piston rings, valves and cylinder walls under boost. It would be like sand blasting the combustion chambers while under boost.
#57
Systemlord is 100% correct. Only way to prevent this is from one of the very few can systems that do stop nearly all the ingestion, and almost all only trap 15-40% tops.....so read a few of the independent long term tests to see. Read the "another legitimate catchcan thread" for all sorts of data.
#58
#59
After having manually cleaned my valves using a combination of picks and walnut shell blasting a couple years back, I'm not convinced that there exists a product that would take that stuff off or dissolve it. People may be getting a marginal amount of the gunk off with chemicals...maybe enough to make a bit of a performance difference....but I have yet to see anyone show any before and after pics of fully-coked valves being totally cleaned by chemicals. The stuff that came off of my valves was virtually hard as a rock and had to be chipped off for the most part.
I'm not insinuating that people aren't telling the truth here...I'm just a skeptic when it comes to using these chemical methods to do a complete cleaning job on really caked valves.
#60
#61
Have you ever seen walnut blasting being performed and seen the actual results? I don't understand how walnut blasting can be called hype, there's plenty of before and after pictures (You Tube videos) showing the results. Perhaps an assumption without having all the facts?
#62
#63
Systemlord is correct.....no damaging residue from the crushed walnut shell media......and I am an actual GM trained tech (back in 1974) and an Automotive Engineer and member in good standing of SAE (Society of automotive engineers) and work primarily on these issues and the solutions for them......tear down and examine and long term test every type gas DI engine you could imagine.
Watch this video if you have any doubt, and I can post tons of pics f the damage CRC/Seafoam/BG and the other solvent based cleaners if any want to see the scouring first hand:
There are thousands and thousands of examples. The crushed walnut shell blasting process is done with the cylinder to be cleaned at TDC so no debris can enter the combustion chamber. The abrasiveness of the media will not harm any component, and no solvent can come close....what the solvent based cleaner do is expand the deposit so a good portion breaks loose and most is expelled out the exhaust port. This shocks the catalytic converter (do a google search to see how many fail immediately after a solvent based cleaning as this debris and solvent hitting the red hot catalyst material fracture it.....and how many turned rod bearings when the oil is not immediately changed after the solvent cleaning as a good amount of the solvent enters the crankcase mixing with the oil and the dilution and debris then circulates through the engine. The oil pump first circulates the engine oil through the rods/mains/on many engines before it reaches the filter, and the filter does not remove the solvent. Again, I travel the country and Canada training service center techs on the new DI engines and the unique issues they have and see all of this time and time again.
Hope this sheds some light for those that don't fully understand all of this as most only base decisions on assumptions, and yes, after a solvent based service of course the engine will regain some lost power and pep.. but at what long term sacrifice?
#64
#65
BMW N54 Engine Intake Valve Cleaning with Walnut Shell Blasting Equipment - YouTube
#67
Please read the thread from the beginning, we're going in circles here. Fuel doesn't touch the valves. You'd clean the combustion chamber a little but not the valves. BMW also recommends not changing your engine oil till 15k miles are you going to do that too? They recommend changing the ATF fluid never. Which is fine if you're leasing the car but if you own it then a little knowledge comes in handy.
#69
I understand how DIs work. My question is regarding the potency of bottled Techron in correlation with pre-mixed Top-Tier Premiums, compared to the other OTC solvents.
#71
This is why I asked user Tuner Boost, who says he’s an industry tech. Figured he might have better info then guesses. As far as your question regarding how (why?) BMW recommends, that depends on what the facts are regarding their potency and effect, which none of us actually know.
#73
I think the point we're all trying to make is regardless of how the solvent works, its the debris that causes the damage. If the solvent somehow vaporizes the deposits then you should be good, but if it causes it to dislodge from the valve it will score the cylinder, and/or break your turbo, and/or overheat your catalytic converter. I'm pretty sure BMW recommends techron as a fuel system cleaner (pour it in the tank) which you know does nothing for the valves. And is a walnut blast every 50k (2-3 times in the lifetime of the car) really that much to ask?
#74
I have used the CRC spray per the instructions. Because I used it in January I can judge the cold weather starts and performance. There is a clear improvement in cold starts but no great difference in mileage. I don't have any microbore pictures and plan on doing more to the valves later. I just have to pick up the special tool for the walnut blast. The MCS has 120,000 miles on it so I am sure there was some carbon build up. It really spit and sputtered when I started it after the one hour soak but it ran nicely after about 30 seconds. For the $16 it cost and the improvement in cold starts, I am pleased and would recommend it.
#75
I used the CRC a couple of months ago and had some improvements of pick and go. A month later I tore the intake off and the valves were still gunk up with carbon. I performed a walnut blast treatment and a lot better now. I personally think the CRC is ok to use on the intermittent between walnut blasting, but does NOT get rid of the carbon build up
