Electrical oem xenon 25w retrofit kit??
Old 03-21-2014, 05:40 PM
wai_jai268's Avatar
wai_jai268
wai_jai268 is offline
Been reading a lot on this thread because I am very interested to getting this for my Canadian Spec Mini.
According to http://www.bmwcoding.com/ , the strobe effect of the light is caused by cold and warm and cold bulb monitoring check. Or at least I am pretty certain that's the case here.
So for you guys who are stuck or don't want to pay hundreds of $$ at the Mini dealerships. This should only take less than 10 minutes to do. Let me know if this works because I am probably going to buy a set of these once I find a seller willing to ship to Canada for a reasonable cost.
With a program like NCS Expert, go to your FRM module and change the following:
Low beam cold monitoring
KALTUE_AL_M1_6_M2_38 set to nicht_aktiv
low beam hot monitoring
WARMUE_AL_M1_6_M2_38 set to nicht_aktiv
Probably should do it for high beam. But try this first.
Let me and all of us know on the forum so we can save some cost from the dealership.
Good luck!!!
  #102
Old 03-21-2014, 08:40 PM
Porthos's Avatar
Porthos
Porthos is offline
So has anyone figured out if you can do the retrofit on an 07?
  #103
Old 03-26-2014, 08:55 PM
wai_jai268's Avatar
wai_jai268
Just going to share what I did to make this work.
1. Install lights
2. Add $522 VO to CAS and FRM module and default car.
3. Thanks to http://forums.bimmerforums.com/forum...non-Headlights. Car now thinks it is on bixenon wiring configuration for the 12 pin connector. So need to tell the car it is using the stock 3 pin connector forh alogen , so need to code PWM_FL_BEI_BIXENON in FRM module from wert_02 to wert_01, wert_01. Now flash to pass works. Also, high beam stays on!!!!!!!
PWM_FL_BEI_BIXENON
wert_01
wert_01
4. Might want to disable auto leveling because you don't have it
Hope this is helpful!!!!!! I am quite happy with the result! Hope no one delete this post.
  #104
Old 04-14-2014, 07:04 PM
Dashdog's Avatar
Dashdog
Dashdog is offline
Originally Posted by ChrisNJ
They will strobe until programed. Install and programming was $65.
Hey Chris- like you I did this upgrade over at Mini Mt Laurel, and I also have the aim issue you did. How exactly did you raise them up? Any help is appreciated.
  #105
Old 04-14-2014, 08:46 PM
Dashdog's Avatar
Dashdog
Dashdog is offline
Whoops-never mind. Did a search and found the answer. Anyone know about how many turns of the adjustment screw got them to the proper level?
  #106
Old 04-15-2014, 12:33 PM
ragingMINI's Avatar
ragingMINI
ragingMINI is offline
1. Install lights
PWM_FL_BEI_BIXENON
wert_01
wert_01
For everyone asking about the pre-2009 models: I am going to check my 2008 tonight to see if I can code these same options. I already have $522 VO added which allows me to run my current retrofit bixenons, but I'm assuming our models don't have the options for the 12 pin vs 3 pin connection. If I can confirm that the pre-2009 models have the same options for coding, I might pull the trigger and try to fit these to my car and report back. $900 is a lot to gamble on some lights, though :/
  #107
Old 04-16-2014, 09:37 AM
OwenRW's Avatar
OwenRW
OwenRW is offline
It would seem like it is possible to make it work on a pre-2009 car: https://www.facebook.com/waymotorwor...52065464003174
  #108
Old 04-16-2014, 09:57 AM
ragingMINI's Avatar
ragingMINI
Excellent! I wonder what the 'trick programming' was. If they release that info, I'll buy them right now...
  #109
Old 04-17-2014, 06:16 PM
WayMotorWorks's Avatar
WayMotorWorks
WayMotorWorks is offline
Vendor
We can install and make them work at the Dragon if your going.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
  #110
Old 04-17-2014, 07:09 PM
ragingMINI's Avatar
ragingMINI
I won't be able to make it :-/ I'm getting a set delivered tomorrow and I'll be trying to figure out the proper coding. I'll report back with my progress and findings.
  #111
Old 04-17-2014, 09:08 PM
8eMINI's Avatar
8eMINI
8eMINI is offline
So I just realized this past week that my high beams don't work @.@ not sure how that happened. I'm guessing it has to do with the way it was coded? Can anyone help me out?
  #112
Old 04-18-2014, 09:25 PM
ragingMINI's Avatar
ragingMINI
OK update on a pre-2009 install
Everything went perfect! After hooking them up, I poked around in NCSexpert for a while and ended up with this combo that didn't flicker and also didn't throw a bulb-out warning:
1. Added $522 VO for Xenons
2. FRM Module Changes:
Disables auto-leveling
AUTO_LWR_ENABLE
nicht_aktiv
Also disables auto-leveling
DYNAM_LWR_ENABLE
nicht_aktiv
Changes headlight pinout
PWM_FL_BEI_BIXENON
wert_01
wert_01
I still have no clue why MINI claims they only work on 2009+ vehicles. I'll post here if anything stops working or is giving me problems, but at the moment, I don't see any issues.
  #113
Old 04-18-2014, 09:45 PM
Agbullet25's Avatar
Agbullet25
Agbullet25 is offline
I was about to say, what was preventing these from being installed on pre-09 cars.
  #114
Old 04-18-2014, 10:39 PM
ragingMINI's Avatar
ragingMINI
Bonus pictures
Attached Thumbnails oem xenon 25w retrofit kit??-img_4403.jpg   oem xenon 25w retrofit kit??-img_4406.jpg   oem xenon 25w retrofit kit??-img_4397.jpg
  #115
Old 04-24-2014, 02:08 PM
Countryman ALL4's Avatar
Countryman ALL4
Countryman ALL4 is offline
Are these supposed to strobe constantly until coded? I was under the impression that it was only during the start-up bulb checks, but mine never stop. Is there something I should check out before I make the 1hr drive to the dealer to find out they still wont work?
  #116
Old 04-24-2014, 02:53 PM
8eMINI's Avatar
8eMINI
8eMINI is offline
Yes, they will strobe until you get your car coded.
  #117
Old 04-26-2014, 01:54 PM
OwenRW's Avatar
OwenRW
OwenRW is offline
AUTO_LWR_ENABLE
nicht_aktiv
DYNAM_LWR_ENABLE
nicht_aktiv
PWM_FL_BEI_BIXENON
wert_01
wert_01
That's pretty awesome. I wonder if WMW can confirm that's what they did also?
I just need $1000 now...
  #118
Old 04-26-2014, 08:15 PM
Porthos's Avatar
Porthos
Porthos is offline
He won't confirm it. It will screw his business model up.
  #119
Old 04-29-2014, 04:52 PM
Tonygba's Avatar
Tonygba
Tonygba is offline
Is this upgrade worth $1000+? I like the look of the original Xenons, but aren't sure about the retrofit's lower light output, the gray (not chrome) interior baffles, and fake washer cover.
What do you think?
  #120
Old 04-29-2014, 06:10 PM
ragingMINI's Avatar
ragingMINI
Originally Posted by Tonygba
Is this upgrade worth $1000+? I like the look of the original Xenons, but aren't sure about the retrofit's lower light output, the gray (not chrome) interior baffles, and fake washer cover. What do you think?
I cannot tell a difference between the light output of the 35w housings and these 25w housings for what it's worth. The gray doesn't look bad, although I still might Joey mod them because I like the black look better. I think if you get the washer jet retrofit, the washers would be functional too. You can't tell that the washers are fake anyway. Are they worth $1000? Who knows. I was just the dumb one who decided I wanted the headlights and splurged before I realized what I was doing :-)
  #121
Old 04-30-2014, 04:18 AM
Tonygba's Avatar
Tonygba
Tonygba is offline
lol. Thx for comments.
  #122
Old 05-02-2014, 11:25 AM
Dashdog's Avatar
Dashdog
Dashdog is offline
What do you think?
I just did the upgrade, purely for the better night vision. I think it was worth it, although my bill came in under $1000. I agree the grey baffles are not great looking, and the fake washer thing is just stupid (not to mention you can't get the covers in black). The light is probably not as good as what you'd get from the standard xenons, but I think it's a big improvement from the regular halogens.
  #123
Old 05-02-2014, 12:32 PM
Tonygba's Avatar
Tonygba
Tonygba is offline
Ok, thx. Still tough to pull the trigger on $1,000, though.
  #124
Old 05-02-2014, 12:38 PM
ECSTuning is offline
Received 1,965 Likes on 1,765 Posts
We have the kit right here in stock if you need it.
Xenon Headlight Titanium Gray 25 W - Set Part # 63102347698KT
http://www.ecstuning.com/Search/SiteSearch/63102347698KT/
  #125
Old 05-02-2014, 01:46 PM
Dashdog's Avatar
Dashdog
Dashdog is offline
Well, the way I look at it, if they save me from hitting one deer (or worse), then they paid for themselves. Cosmetically, they do improve the look of the car, but not worth a grand for that alone.
Quick Reply: Electrical oem xenon 25w retrofit kit??
