R56 Turbo Oil Feed Line Tutorial
Old Jun 16, 2013 | 11:59 AM
hudub's Avatar
hudub
Hello all,
I finally got around to writing up a tutorial on how to fix the all too common leaking Turbo Oil Feed Line tutorial. I was able to complete this because of all the helpful posts and people on this forum, so thank you all. Check it out and hopefully this helps someone with this issue instead of paying $1k+ at the stealership!
Article
Old Jun 16, 2013 | 02:47 PM
InjectedGT's Avatar
InjectedGT
any particular reason all of that needs to be replaced if it's the o-ring on the top banjo bolt causing the issue?
Old Jun 16, 2013 | 06:56 PM
mbwicz's Avatar
mbwicz
The O-ring that fails is in the joint from the flexible line to the end fitting. It is not replaceable.
Mike
Old Jun 16, 2013 | 07:04 PM
InjectedGT's Avatar
InjectedGT
Dang! That sucks. Crossing my fingers it doesn't happen to me on my 07. Not that I can't do it, but why would I want to? lol
Old Jun 16, 2013 | 07:15 PM
bccan's Avatar
bccan
Nice job & thanks for the effort you put forth to help out those who will have to got through this. Even if paying someone else to do it folks will understand what is involved & be able to judge pricing as an informed consumer.
Old Jun 16, 2013 | 07:51 PM
danjreed's Avatar
danjreed
I had the same question.. Unless the OE line had internal rubber seals... In which case I'd just toss in some copper brake washers.
Old Jun 17, 2013 | 11:59 PM
tw1112's Avatar
tw1112
That lower heat shield is such a pain! Any tips on getting it off? Those top screws are so hidden up there...how did you get them back on?
Old Jun 15, 2025 | 05:35 AM
scf's Avatar
scf
The gift that keeps on giving!!
Doing a turbo swap today, and this write-up was extremely helpful!!
Old Jun 15, 2025 | 04:09 PM
Seaswood's Avatar
Seaswood
Undo the battery the alternator is under there, I found out.
you start removing bolts until it comes off, helps to move frame apart.
sevin
May 2, 2026 06:11 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
devicemanager
Jun 17, 2016 06:18 PM
PelicanParts.com
Aug 14, 2015 11:07 AM
