R56 how do you open the air box?
Old Mar 21, 2012 | 06:44 PM
btor's Avatar
btor
Want to change my air filter. Do you just loosen the screws on the front of the box? Are there any other tricks i need to know?
Old Mar 21, 2012 | 07:02 PM
Maugre's Avatar
Maugre
Loosen the screws, disconnect the connector for the air flow sensor, and the hose clamp on the housing, and wiggle it free.
Old Mar 21, 2012 | 08:27 PM
Benibiker's Avatar
Benibiker
I just loosen the screws and can open it enough to get the old filter out and the new one in.
Old Mar 21, 2012 | 09:16 PM
Bmont82's Avatar
Bmont82
No need to un-due any connectors, simply remove the torx screws surrounding it. It takes a little finesse to get the back of the box loose but it will come out.
Old Mar 22, 2012 | 05:08 AM
btor's Avatar
btor
Thanks, i knew it was easy but i had to ask.
Old Mar 22, 2012 | 07:08 AM
drsimmons's Avatar
drsimmons
If you haven't gotten it yet, do what Benibiker said.
It lifts up enough to get old out and new in.
Old Mar 22, 2012 | 07:16 AM
Maugre's Avatar
Maugre
I guess the reason I like to remove it completly is because then you can
clean out the dead bugs and other swarf that accumulates in the bottom
of the housing, but thats just me . Good luck.
Old Mar 22, 2012 | 07:23 AM
drsimmons's Avatar
drsimmons
^^^Good idea. Maybe my 07 is a little different but I was still able to vacuum in there w/o removing anything other than the screws and pulling
the cover out of the way slightly.
I've since changed to a CAI so no issue with vacuuming.
MoganDavid
Mar 14, 2016 10:44 AM
The_Kid
Aug 28, 2015 04:50 AM
mikeyb74
Aug 24, 2015 12:13 PM
M7Speed
Aug 6, 2015 01:48 PM
