R56 NHSTA MINI 2007- 2011 Recall
#276
DEFINITELY try again. It was not official several months ago, and JUST became official as of mid-October. Give it a whirl.
The service manager told me this about the process ..
- If they haven't already, the dealership will pull the VIN to check the history and see if timing components have ever been changed before.
- They will inspect the timing chain slack.
- If it still has the old part number, they will replace all of the timing components.
- If you have an updated or newer part number, it falls outside of the service campaign.
- If you have issues with newer components or fall outside the campaign range, how dealerships handle that is at their discretion.
They will also be doing the heat shield for my MCS as well - that is under a recall right now.
#277
on
I still haven't gotten a letter about it. The MINI USA lady said they started going out in October, and they do have my new address, so hopefully that won't delay anything. The good thing was that my car was confirmed to be covered by the service bulletin (don't call it a recall!).
Keep your fingers crossed!
#278
#280
#282
Got my notice in the mail today for the timing chain, but my situation is somewhat complicated. Last summer I started getting the timing chain rattle, and when I took the car in they told me how bad it sounded and it needed to get fixed ASAP for 1200 bucks. I went home and installed the new timing chain tensioner myself and its been fine till recently when its started to get cold out and the rattle is back, though only slightly.
The car has just under 100k miles now, so I imagine the chain has stretched a fair bit, but since I put in the new tensioner myself, will they try to get out of doing a full parts swap?
I also need a thermostat and turbo oil feed line put in, what are the chances they'll do it cheaper since they'll already have most of the engine apart and the labor for it will have been done for the timing chain (assuming they do it)?
#283
on
#284
Got my recall notice on my 2008 S recently... Thought I'd report in my results.
While I live in Asheville, NC.. I had a biz meeting in Nashville, Tn the following week so I called Mini of Nashville, set up an appointment, and told them I needed a loaner car while in town. They explained they would open her up and evaluate the situation then replace the timing chain if necessary.. Upon drop-off, he looked up my car and also found another recall notice was pending regarding putting a heat shield over an oil line so they'd take of that while I had it in. Cool
I dropped off the car at 9am on a Tuesday was told the car would be ready by end of day. They provided a Mini loaner. Late in the day they called and told me that A. the timing chain did need to be replaced and B. The car would NOT be ready until 11am the next day. I had planned on leaving town before noon anyway so the delay was fine with me as long as the car was fixed correctly...
The next morning I showed up at precisely 11am and (I'm not kidding).. I turned over the loaner, signed the paperwork, was handed my keys, and was out the door in under 4 minutes. Cost to me.. $0. Stellar service from Mini Of Nashville. They even washed it for me. Sweet. They mentioned that in order to replace the timing chain they had to drain and replace with all new oil.
It's been about 3 weeks now and the car is so much quieter now.. This is my first Mini and I had just assumed the noisy timing chain was just part of the eccentric charm of Minis.. kinda like clunky shifting on BMW motorcycles.. I was wrong... the engine hums now.. a night and day difference.. Mongo happy..
#285
on
An update on my reimbursement. First, to recap, I had the work done by my original selling dealer exactly a year ago (tomorrow!), before my move to Arkansas. I did so partly because the chain was noisy, partly to prevent worse problems, and partly because I was moving to a place where there was no dealer, and I didn't know who could service MINIs. I paid for it myself, well over $1300.
After establishing a relationship with an independent garage in Little Rock, I was told that MINI was starting to reimburse for this work. I called MINI USA and was referred back to the dealer who did the work, saying that it was on a case-by-case basis, by the dealers themselves.
Now comes the gotcha. No one's denying that I had the work done on my nickel, or that it was done at a MINI dealer. My car does fall into the service campaign (not a recall) parameters. Reimbursement is apparently in my future, but FIRST, I was told I have to have the car inspected by a dealer to make sure the "right parts" were used last December. The person I spoke to in Houston said that the part has been redesigned 4 times--not sure exactly which part she meant--and she didn't know which was used in my car's servicing. We'll have a dealer opening in Little Rock within the next few months, and it makes more sense to wait, rather than to drive 800 miles round trip to the dealer who did the work, or 400 miles round trip to the current nearest dealership, in Memphis.
So, I'm not real happy about the delay. What happens if the "right part" wasn't used? Will they reimburse me for the work that was previously done, as well as what is needed to make things right? Why not cut a check to reimburse for what I already paid, with the knowledge that it also needs an inspection for this and also for the turbo shielding?
Thoughts, anyone?
Thoughts, anyone?
#286
Thoughts, anyone?
Thoughts, anyone?
If the right part wasn't used and the dealer is the one who installed it that makes the dealer and Mini USA responsible, if done at a non-dealership that changes things!
#287
on
I called Mini USA about my reimbursement and was also referred to my local dealer, said to come in and present the dealer with my receipt and less than two weeks later had my check in my mail box! Now that Mini USA is acknowledging that there is indeed a defective component in the timing chain components they are now fully responsible for any out of pocket expense.
The work was indeed done at a dealership--the one that sold me the car back in 2007--and I do have the receipt. In fact, they even emailed me a copy of the receipt, so I know they have it, too! I don't know who's ultimately paying for this "campaign," but I notice that the person I spoke to suggested that the as-yet-unopened dealer in Little Rock could give me the reimbursement. Seems like passing the buck.
After thinking about it, I'm going to go higher in the food chain. I don't personally know the person I spoke to on the phone, but I DO know the dealer manager, and the guy above him. I'll have a chat with the manager next.
I'll keep you posted!
#288
After having the car in the shop last week for another round of MINI problems, today the CEL came on and the car went into limp mode. I "limped" to the dealership and told the SA that I thought it was the HPFP, which she said "wasn't likely" and that it was probably carbon buildup. Well, three hours later, I get a call that the computer programming at the dealership found the HPFP was failing. According to the dealership "no buildup was present" but I doubt the even looked. This is just another chapter of my never-ending saga of problems with this car. For a 2011 Cooper S to have been in the shop nearly as many days, as it has been drivable, I feel MINI is at fault for their crappy manufacturing. I've really thought about demanding a Buy-Back from MINIUSA, but I'm almost positive the wouldn't do anything except tell me to keep taking it to the dealership over and over. It's crazy.
#289
on
Hope you get this settled. I haven't had anything like this, but I can understand your frustration.
#290
#291
on
Don't count on BMW corporate to read these boards--I've never seen any evidence that they do. I would, however, reference the statements you've made, just so they know that the MINI world is watching for their response.
#292
1. Timing Chain Failure.
2. Valve Cover.
3. Thermostat Housing
4. Soon Fuel Pump In Gas Tank making spinning shaft screech almost like it's rusted.
Who was your local dealer, Systemlord? How recently was the work done, and did you have to go through any hoops, like an inspection?
#293
I hate it when the SA or techs start guessing at what might be the problem, it's your wallet their playing with. They need to check the ECU for codes before opening their mouths! A part of me is wishing I never bought a Mini Cooper S, but now that I have put so much money into it, I'm committed. I don't see myself walking away from it. 1. Timing Chain Failure. 2. Valve Cover. 3. Thermostat Housing 4. Soon Fuel Pump In Gas Tank making spinning shaft screech almost like it's rusted. Irvine Mini in California.
#294
Timing Chain Reimbursement
My experiece so far with reimbursement...I recently had to take my 08 MCS to the dealer due to electrical issues and they informed me of the ongoing campaign for the timing chain/ tensioners. I had previously had the timing chain fix done in January 2012 so I decided to try to get reimbursement to offset some of the damage from the electrical fix. As it stands right now I'm being denied reimbursement because there isn't sufficient maintenance record for oil changes. I had bought the car in Oct 2011 with about 51K on it from a non-Mini dealer; by Jan 2012 I had the car at the Mini dealer to do a timing chain. According to Mini the last service record they have before the timing chain fix at 57K was at 35K. Because of this 22K mile gap in service history, specifically between oil changes, I won’t be reimbursed. I'm in the process of trying to dig up as much info as I can from the dealer I purchased the car from but I don’t have high hopes. Any suggestions or advice much appreciated.
#295
on
#296
I would just like to say that Mini took good care of us. We are the second owner of an 09 MCS, with no service records of any kind at 95k. Car was covered by the campaign, they gave us a new loaner and had our car about 3 days. New timing chain set, tensioner, aux water pump, turbo heat shield, all at no charge. Rattle is gone and I have peace of mind!
#297
on
Update: STILL no reimbursement from MINI of The Woodlands. I'm frankly disappointed in them. The word is still that I have to get it inspected by a dealer, and since the closest one currently is a couple of hundred miles away in Memphis, I'll wait until April when Little Rock gets a brand new dealership. I'm angry that I have to do that. Frankly, it's irrelevant, because the original work was done at MINI of The Woodlands (Houston area), and they even sent me a copy of the bill. All the new dealer is going to do is verify that the right parts were used, but even if they weren't, that doesn't negate the original mega-buck payment I've already made to MINI of The Woodlands!
It's been over a year since the work was done, and I could use the money. MINI USA should handle this, not the dealer, and MINI of The Woodlands should have cut the check as soon as the service campaign was released. P1SS poor customer relations on the part of both entities, as far as I'm concerned.
Up until now I haven't released the name of the dealership, but I'm doing so now. I don't deserve the runaround I've gotten.
#298
#299
on
As I pointed out, I've got a MINI and my 5th BMW side by side in my garage, so there's an incentive there to make it right at the corporate level.
#300
