R56 How to get Auto-Up Windows?
Old Aug 16, 2011 | 10:05 AM
  #26
YELLOWMINIAZ's Avatar
YELLOWMINIAZ
I didn't have the auto up option on my 2005. I had Way Motor Works install it for me. It took him a whole 2 minutes and the cost was $50.00. Well worth it! I can still use my key from the outside to roll up windows and close the sunroof.
Good luck to ya!!
Old Aug 16, 2011 | 05:02 PM
  #27
alexs3d2's Avatar
alexs3d2
You can code the auto-up feature with NCSExpert. I've got a 07 EU model and have programmed the car to auto-up both driver's and passenger's side and closing of the windows and sunroof through the fob (opening was already stanard feature).
There are explanations on how you can do it in the "Electrical" section of the this forum.
Old Aug 16, 2011 | 07:09 PM
  #28
YELLOWMINIAZ
What is NCS Expert?
Old Aug 16, 2011 | 07:14 PM
  #29
orangecrush's Avatar
orangecrush
Originally Posted by YELLOWMINIAZ
What is NCS Expert?
New Car Syndrome.... gotta buy a new car every two years... Guess that makes me an expert.
:D
Old Aug 16, 2011 | 07:15 PM
  #30
YELLOWMINIAZ
I'm not ready to give up my beauty yet!!
Old Aug 17, 2011 | 07:59 AM
  #31
alexs3d2's Avatar
alexs3d2
"NCSExpert" is the coding utility used by BMW engineers during vehicle development. You can change the same settings a dealer can (+more), but in a more crude manner.
A good information resource is the site BMW Coding. THis site also has nice threads on the job...
Old Aug 17, 2011 | 08:28 AM
  #32
orangecrush
Yeah, what he said...
Thanks Alex, I was so busy being a smart *** I forgot to actually tell her what it was...lol.
Mark
Old Aug 17, 2011 | 12:48 PM
  #33
YELLOWMINIAZ
Ya thanks Alex.
Let truth be known he probably didnt know what it was...LOL
Old Aug 17, 2011 | 02:01 PM
  #34
callahan00's Avatar
callahan00
Auto up windows were not available on the R56 until the 2008 model year. Auto up on the convertible was not avaialbe until 2009 when the convertible was switched to the generation 2 platform.
To get it on the 2007, you would need to have Way Motor Works program it for youo [or buy the cable] There is a thread regarding this.
Old Aug 17, 2011 | 02:11 PM
  #35
John Walker's Avatar
John Walker
THANKS for this info! I just did this on my 08 and worked like a charm!
Originally Posted by 10Zero
Just in case:
Insert the fob, hold both window toggles "down" at the same time until the windows are fully open.
Pop the fob out, then back in again, hold both toggles "up" until fully closed.
Pop the fob out, then back in again...you should have auto up/down again.
Old Sep 25, 2011 | 02:34 PM
  #36
TheCheatOSX's Avatar
TheCheatOSX
Alex, I see you added the FH_MAUT_ZU_ACTIV_FAT to the NCSExpert spreadsheet to activate auto up on 2007 models. I've programed these in the FRM but still no auto up. Is there anything else you had to do to make it work?
Old Sep 25, 2011 | 11:18 PM
  #37
alexs3d2's Avatar
alexs3d2
Hmm... That is strange. No I didn't change anything else, but there could still be another setting somewhere which is overriding these. My car already had auto-up fro the driver's door, so I just changed FH_MAUT_ZU_ACTIV_BFT to AKTIV to also get the co-driver's door to do that.
Keep in mind, the auto-up ONLY works with the ignition or engine ON. Auto-down works with JUST the key inserted, so if you were testing it as such it wont go up
If you still can't get it to work, search for other settings in the FRM and CAS modules which have "MAUT" in the wording.
Old Sep 26, 2011 | 05:43 AM
  #38
TheCheatOSX
We have a winner! Tested it this morning and it works great. Also programmed in the "keep going up when opening door" and it works too. Thanks for the info!
Old Sep 26, 2011 | 11:36 AM
  #39
Neitherfanboy's Avatar
Neitherfanboy
On my 2009 MCS, I can hit the switch for auto-up with just the key in the ignition, car not running, I do it almost every night.
Old Sep 26, 2011 | 04:52 PM
  #40
TheCheatOSX
Auto up was not default in 2007 cars. I'm guessing that is the difference. There is more than likely another setting in FRM for that just waiting to be discovered for us 2007 owners. Time to translate more MAUT settings!
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
