R56 Heated Mirror operation
Old Oct 28, 2010 | 07:43 PM
DOC4444's Avatar
DOC4444
2010 Justa: Apparently the heated mirrors don't always automatically turn on with the rear window "heat" switch. The owners manual is vague about it, but seems to imply that they turn on "when needed".
Is it possible to reprogram to get the mirrors to always heat along with the rear window?
If not, is the temp that they turn on adjustable? If so, how?
(My mirrors are always misted early in the morning along with the rear window.)
Thanks,
DOC
Old Oct 29, 2010 | 07:07 AM
schatzy62's Avatar
schatzy62
Not totaly sure about 2010 but earlier years the heated mirrors were not attached to the rear window defogger. There is a set temp in the computer and they come on as needed.
Old Oct 29, 2010 | 09:45 AM
Walt's Avatar
Walt
Possibly at 37deg? The same as the "icey road" warning???
Old Oct 29, 2010 | 11:47 AM
BGR Alex's Avatar
BGR Alex
The front headlight washers are heated at a pre-determined temperature. I can't remember the temp, but I think it was warmer than the 37 degrees at which the snowflake gong appears.
Old Oct 30, 2010 | 12:00 PM
DOC4444's Avatar
DOC4444
Nobody has any ideas about reprogramming to a higher temp, linking to the rear window switch or adding a separate switch?
(Wiping the mist off the mirrors before backing up does not work very well unless the mirrors are starting to heat up. Cold, they just remist almost instantly.)
Thanks,
DOC
molala
Oct 2, 2015 01:53 PM
Norton70
Sep 7, 2015 05:06 PM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
