R56 Rough idle - sounds like a diesel
Old Apr 27, 2010 | 09:34 AM
MDL8440's Avatar
MDL8440
So at cold start my car sounds like a diesel. I had the HPFP recently replaced under warranty so I thought that might fix the issue. The car performs fine after it warms up a bit. Although, after it has warmed up it can still doesn't really idle as smooth as I would think it should. I have honestly never been in another MINI turbo other than mine nor have I heard any up close and personal so is this normal? I know some people have had their timing chain tensioner replaced so I'm not sure if this would be the result of a weak tensioner or what.
Old Apr 27, 2010 | 09:48 AM
OPC's Avatar
OPC
RATTUS Deserticus
No, it is not normal. Check out the sticky in the Stock Problem / Issues section: Cold Start Issues Database
Old Apr 27, 2010 | 09:56 AM
Robin Casady's Avatar
Robin Casady
It depends on what "sounds like a diesel" means. The timing chain tensioner problem (cold start chatter) gets worse at higher revs. (Don't go above 2,000 if it chatters). It sounds like a chain being dragged across bare metal, which is exactly what it is.
A ticking noise at idle is normal. It is the injectors.
My MCS runs quite smoothly at cold start, now that the chain tensioner has been fixed, and I started using Castrol Syntech 0W-30 European Formula (Made in Germany) motor oil.
Colt45Magnus
Aug 27, 2024 05:03 AM
Camden90240
Sep 28, 2020 12:09 PM
ShadyCoop
Sep 11, 2015 11:14 AM
