R56 Only 410 miles and exceed 4500rpm
Old Jun 24, 2010 | 12:00 PM
  #26
Bigprfed22's Avatar
Bigprfed22
exactly
Old Jun 24, 2010 | 12:06 PM
  #27
richardsperry's Avatar
richardsperry
Drive it like you stole it. The engine will be better for it.
Old Jun 24, 2010 | 01:30 PM
  #28
Bigprfed22's Avatar
Bigprfed22
i was a honda trans tech for 2 years... build moto race engines for myself, in my opinion break in should be constant changing revolutions, not one steady limit so the heat expansion is through the rev range... manufacturers IMO set those limits so that if something fails, it is not catastrophic to you or the car... kinda like a "see if it shakes loose" type bit. the manual states to consistently change revs.
Old Jul 12, 2010 | 12:58 PM
  #29
RedDog888
It's more important on a new engine not to run it for long periods of time during break in. The rings set up fast, the wost time for them is at the intial startup.....galzing. Mass produced engines have a little tighter tolerance and need to work in/wear in the parts during break in periods because they don't machine all the parts to a high tolerance, they let them work in, cheaper for OEM. Race engines are machined to tighter tolerances and don't need to "work in" to get their intended gaps. So during break in you will get more heat generated by the parts as they work in. Don't forget, as parts get hotter they expand, and the gap tolerances go down. So you don't want to push it until those gap tolerances are set up and at high temps you still have the needed gap to maintain a good oil film which is what you need for slip.
Vary RPM is good during break in, just don't tac it to red line all the time and for long periods of time holding it at high RPM.......which is critical to have proper oil film layer between moving parts.
Old Jul 12, 2010 | 01:06 PM
  #30
Bigprfed22's Avatar
Bigprfed22
Varying rpm is the key, changes the engine temp often and allows for the expansion and wear, good advice
Old Jul 13, 2010 | 09:23 PM
  #31
kukaepe's Avatar
kukaepe
I was taught by a top drawer engine builder that if you baby an engine when it is new it will always run like it was babied. I actually drive the car harder when new than after break in....drive it like you stole it when it's new and it will run strong forever. Just one guy's opinion.........
Old Jul 17, 2010 | 01:27 AM
  #32
jdmef8's Avatar
jdmef8
Totally agree with this. I've taken test drives in MINI's and have taken them to redline with only 13 miles on the odo. I'm sure I'm not the only one whose done this, as the MA told me to "floor it".
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
phrza81
Oct 10, 2015 11:37 PM
ltjpunk7
Sep 6, 2015 07:32 AM
kyungmanpark
Aug 23, 2015 07:26 PM
Powershift
Aug 16, 2015 05:14 PM
