R56 Comfort Acces - Unlocking Passenger Door
Old Aug 11, 2009 | 06:51 PM
  #26
schatzy62's Avatar
schatzy62
Originally Posted by Robin Casady
There is a setting that lets you choose whether the passenger door is unlocked when you unlock the driver door. If this is set, as it is on the OP's MINI, then the passenger cannot open his/her door with the black button on the handle.
I set my car this way and hung the fob on the driver side door handle. Then went around and tried opening the passenger door. It wouldn't open.
I set it to open both doors, and tried it again. This time the passenger could open the door with the black button.
So, if you have it set in Terrified Loner Mode, to let a passenger open the door, you have to pull out the fob and hit the unlock button twice or get in and hit the unlock toggle switch.
If you have it set in Gregarious Fool Mode, the passenger can open the door if the fob is within range of the car.
This is correct and if it works any differently there is something wrong with the programing of the computer in the car.
Old Aug 11, 2009 | 11:17 PM
  #27
PoktRokt's Avatar
PoktRokt
without opening the manual, how do you program these things? and is there an option to set the alarm differently so it beeps when you set it?
Old Aug 12, 2009 | 04:20 AM
  #28
schatzy62's Avatar
schatzy62
That is why they make a manual for the car. So you can open it and learn these things.
If you have the alarm system yes. If you do not have the alarm system then you can not get it to beep.
Old Aug 12, 2009 | 12:43 PM
  #29
Robin Casady's Avatar
Robin Casady
You select Car Settings on the NAV screen. It should be fairly obvious from there.
Wont read the manual, and want to annoy people around you when you set your alarm. Hmm, you're working up some bad karma there PoktRkt.
Old Aug 12, 2009 | 12:56 PM
  #30
markusw's Avatar
markusw
His next question will be "Where is the NAV screen?" .
Old Aug 12, 2009 | 07:39 PM
  #31
Dimples's Avatar
Dimples
I am so the Terrified Loner!!!
And this is the first time I've ever had a two page thread! Yay for me!
DeniseNY R52
May 17, 2016 05:16 AM
xpunisherx
Sep 1, 2015 11:47 AM
kellymac
Aug 30, 2015 10:11 PM
polotska
Aug 23, 2015 03:03 PM
