R56 For MCS: At what rpm does the turbo start to scoop up? Whats the mph?
Old May 17, 2009 | 04:42 PM
stockae92's Avatar
stockae92
For MCS, at what rpm does the turbo start to scoop up? Whats the mph at that rpm?
(so below that rpm for cooler engine temp, mpg for cruising)
Old May 17, 2009 | 04:43 PM
GTI EATER's Avatar
GTI EATER
you mean spool up?
Old May 17, 2009 | 05:33 PM
jtom's Avatar
jtom
Originally Posted by GTI EATER
you mean spool up?
hahahaha
Thats the first thing I thought of when I read the title of this thread.
Old May 17, 2009 | 07:01 PM
MPowerF1's Avatar
MPowerF1
1500 rpm, in my experience.
Old May 18, 2009 | 09:29 PM
Ken G.'s Avatar
Ken G.
The twin spool turbo has a really low spool up speed. Like MPowerF1 says, it's nearly immediate. Having said that, the turbo doesn't seem to ding the milage much, just keeping the speed constant seems to be the best way to get good milage. I once got 42 calculated MPG by cruising all day at 60 mph using cruise control.
Old May 18, 2009 | 11:30 PM
Oxybluecoop's Avatar
Oxybluecoop
Check this info out.
Attachment 41226
Old May 19, 2009 | 09:24 AM
tambi's Avatar
tambi
Great piece of info..!
This suggests that the MCS is a direct injection engine, while the MC isn't.. something I wasn't aware of!
Thanks Oxy
Old May 19, 2009 | 09:45 AM
countryboyshane's Avatar
countryboyshane
It's does spool up rather fast, but you really FEEL it around 1500-2000rpm on the butt dyno.
Old May 19, 2009 | 10:05 AM
misslindsey's Avatar
misslindsey
You start to get full boost about 2500rpm, it starts to spool up below 1500. To get speed, stay above 2500-3000, to get fuel economy, shift before you get there.
Also, if you're cruising at any speed (70-75mph) you'll be into some boost whether you want to be or not.
Old May 19, 2009 | 12:46 PM
sequence's Avatar
sequence
I wonder if the current MCS engine has diff specs-- that attachcment is dated 2004, and only details the 118 and 148 HP versions
Old May 19, 2009 | 06:16 PM
jcauseyfd's Avatar
jcauseyfd
Is there a source for the claim that cruising at highway speeds will necessarily put you into boost?
Old May 19, 2009 | 06:20 PM
tambi's Avatar
tambi
Not sure about source, but I'm guessing the basic idea is that if you're engine rpm & exhaust flow is high enough (which it is during highway cruising), you would definitely spool the turbo.
Anybody with boost gauges willing to testify?
Old May 19, 2009 | 06:51 PM
canadianprime's Avatar
canadianprime
In my factory JCW I run at about 10-12inches of vacuum while cruising.
Old May 20, 2009 | 04:33 AM
tambi's Avatar
tambi
Huh.. I would have thought otherwise..
I need to get me some boost gauges..!
Old May 20, 2009 | 05:52 AM
Paleo's Avatar
Paleo
In my MCS the boost starts to build at fairly low RPMs when accelerating, but really kicks in around 2500. When cruising at 60 mph or higher my boost gauge reads just over one PSI, lower speeds (ie: lower RPM) it settles to zero. I have never seen the gauge reading in vacuum under any driving situation.
Old May 20, 2009 | 09:21 AM
canadianprime
and then when i give it any gas it will jump to 10psi and climb as high as 20
Old May 20, 2009 | 09:16 PM
Dwight Walhood's Avatar
Dwight Walhood
R56 Turbo Spool-up
Shortly after I got my '08 MCS, my service manager kindly copied the factory spec sheet for me. It states full torque (177lb.-ft) from 1600-5000rpm and overboost (191lb.-ft) starting at 1600rpm. The twin spool turbo explains this quick spool-up, but you have to be some kind of engineer to understand how it works. The big torque and quick spool-up explains why the
Getrag 6spd is OD in 5th & 6th gears!
Turbo On - Dwight
rob&JCW
Feb 13, 2023 07:03 PM
theblackfalcon
Oct 11, 2015 09:49 AM
David.R53
Sep 1, 2015 06:49 PM
DWooderson
Aug 20, 2015 04:31 AM
