R56 Hood temp problems resolved
Old Oct 17, 2008 | 07:25 PM
  #51
orangecrush's Avatar
orangecrush
Originally Posted by WYSIWYG
Just to clarify, the turbo uses the engine's oil.
Guess I'm still thinking I've got a supercharger.... what an idiot...
Thanks bud,
Mark
Old Oct 18, 2008 | 04:23 PM
  #52
Benibiker's Avatar
Benibiker
The M7 Heat Shield still gets very hot to the touch but it seems to spread the heat out over a larger area instead of concentrating the heat right under the scoop as the "shieldless" turbo does. I attached a thermo blanket under the scoop with a cutout to let the cool air in and hot air out through the scoop opening after shut down. I think just the thermo blanket would have been enough as it kept the scoop area very cool. The addition of the M7 shield had a minimal effect in my case. On the attached photo you can see where I installed the blanket and later cut out the scoop area with a flap going onto the inside top area of the scoop. The blanket has adhesive on one side and I also put thermo tape on the edges. Might not look that nice but it works great! The blanket and tape were $20 compared to about $200 for the M7 heat shield.
Old Oct 18, 2008 | 04:54 PM
  #53
slinger688's Avatar
slinger688
Benibiker,
What type of thermo blanket are you using? Thermo tec?
Is the glue still holding after a few heat cycles? Is there any burning over time?
Old Oct 18, 2008 | 05:17 PM
  #54
Benibiker's Avatar
Benibiker
Originally Posted by slinger688
Benibiker,
I used Thermo Tec around the edges but in the middle area I used a "Cool Ride Self-Adhesive Super Insulated Sheet" (P/N CR2424 at HRPWorld.com). It's 1/8" in thickness and I haven't had any burning and I've had it on about 2 months. At first the glue would let go on the Thermo Tec but after pressing it down a couple of times it held. No problems with the glue on the Insulated Sheet though.
Old Oct 18, 2008 | 06:54 PM
  #55
gbsim's Avatar
gbsim
Just curious as to why you used two types of themal blanket? Why not just the cool ride? Thanks.... seems like an easy "fix" and I may give it a try.
Old Oct 18, 2008 | 07:00 PM
  #56
Benibiker's Avatar
Benibiker
The Thermo Tec is about as thick as duct tape and the thermal blanket is 1/8" in thickness. I used the Thermo Tec around the edges of the blanket to keep the internal fibers from coming out of the edges.
Old Mar 10, 2009 | 03:14 PM
  #57
n733lk's Avatar
n733lk
Excuse my ignorance, but how does the heat shield keep the temp DOWN? I'd think this would only serve to keep the heat in and raise the actual temp under the hood.
Old Mar 10, 2009 | 03:18 PM
  #58
n733lk's Avatar
n733lk
Has anybody drilled additional holes in their scoops? There seems to only be about 30-40% of the available slots actually cut out of the scoop design.
Old Mar 10, 2009 | 07:29 PM
  #59
Pinky Demon's Avatar
Pinky Demon
Originally Posted by maximus96
i thought the padding effectively block any air coming in from the scoop, is that not the case? sure looks that way.
Nope. There is a vented portion of the heat blocking material that allows air from the scoop in.
Old Mar 10, 2009 | 07:37 PM
  #60
Pinky Demon
Originally Posted by morbius
Mark,
The turbo wrap is specially made for the mini R56 turbo. It made by Way Motor Works [ http://www.waymotorworks.com ]. It is designed to handle the heat that the turbo produces.
Direct link: http://www.waymotorworks.com/product...1&cat=0&page=1
Cheers.
Could you elaborate as to why the install on the wrap was difficult?
Old Mar 10, 2009 | 08:11 PM
  #61
n733lk's Avatar
n733lk
Did you use anything other than the self-adhesive to secure it under your bonnet?
Old Mar 10, 2009 | 09:38 PM
  #62
Benibiker's Avatar
Benibiker
I'm going on 5,000 miles with the thermo blanket and the heat shield, still no warping... Who knows it might not have warped either way...
Old Apr 2, 2009 | 02:47 PM
  #63
n733lk's Avatar
n733lk
Just ordered the thermo blanket. Not quite so cheap anymore! They must have read your thread! Anyway, how's it going? Still working well? Any downsides?
Old Aug 23, 2009 | 12:19 AM
  #64
Benibiker's Avatar
Benibiker
Now going on 8,000 miles, still no issues. At first the self adhesive blanket wanted to come un-glued but it eventually stuck on there.
Old May 17, 2010 | 10:52 AM
  #65
bagwell's Avatar
bagwell
I drilled out all the center slots on my recently replaced scoop + I bought the M7.
this pic is before I cleaned it up with a file...but you get the idea (white paper is there just to show the openings)
iggi
18
Feb 9, 2026 01:00 AM
Kimolaoha
Jul 5, 2023 01:04 PM
rckrzy1
Aug 11, 2015 06:06 PM
