R56 JCW Shift Knob Installation Help Needed
And, if you ever think you might want to reuse the stock **** for something do not try to turn it like it's threaded, there's a little plastic piece that breaks off then the **** will spin on the shaft, usually when you're trying to grab it rapidly and your hand slips off, but it does make a nice paperweight.
on
yup, as they said, pull straight up.
however, you need to get the boot off of the center console before you pull up.
there's 8 clips holding a circular plastic holder thing for the boot. Some say you can just pull on the clips through the boot to get the boot off. I think that's impossible. I lifted the center console up, by undoing three torx screws. they're located in the two cup holders up front, and the one in the back. Then, lift up on the center console, keeping in mind that the e-break boot is attached to it as well. I used a mirror so I could see what I was doing, and used a screwdriver to push on the tabs. It helps if you have 8 hands, but since you probably dont, just start on one side and work your way around... once you've got a few done, you should be able to just pull up on the boot.
Now that you've got the boot un-attached, pull up hard on the shift ****, it'll pop off.
Then, un-attach the boot from the old shifter. there's a black ring that holds the boot onto the ****. squeeze the four clips using your first four hands, and then use your other hand to pull the ring off of the ****. The ring is attached to the boot, so don't pull on it.
re-installation is much simpler, just clip everything back in.
on
I used this to help show me how to remove the shift boot.
http://www.robincasady.com/ShiftKnob...otInstall.html
ok installed my jcw shift **** and it looks great and was easy too i used this to help me if anyone else is doing this
http://www.robincasady.com/ShiftKnobs/Installation.html
thanks to everyone for the help
I just installed the JCW shift **** and boot. The **** pulled right off, with some bit of force, as everyone has stated.
You do not need to remove the console to change the shift boot. What I did was to tug on it enough to slip a credit card in bewteen the boot base and the console (towards the rear). Then I slipped a second credit card in and spread the two apart until the boot tab separated from the console.
Then it was just a matter of pulling harder to free it. I plan to take the same approach with the e-brake boot.
on
I'm very confused about how you managed to get your boot off without taking up the center console. I just tried the credit card method just to check it out, no go.
Even when I got my console out, which btw only takes 3 screws and 2 mins at most, the tabs holding the boot holder into the console were too big for the actual console hole. it was physically impossible to squeeze the tabs into the holes. I had to wedge a screw driver in next to the tabs and deform them in order to get them to release from the console.
maybe I got some malformed console or boot holder thingy, but the way you guys are saying was abosolutely not possible on my car.
Not in terms of the shifter, and most of the rest of the interior. I doubt the console and boots are any different between them. The JCW does get a standard shift **** that is different from the MCS, but I'll bet everything else about the console is exactly the same.
I just pulled me OEM shift **** and it came out fine, WITH the boot still intact to the shift ****. Clips just popped off on the boot bottom. So I had the old OEM **** and the boot in my hands. My problem is HOW I get the boot unattached from the ****? I've turned it inside out and am wondering the best way to do this.
I've read about the "butterknife" method, credit cards, etc. Any "best practice" to make this happen? I've got an 09 JCW.
