R56 Oil leak from bottom of hatch door?
Old Jun 21, 2008 | 10:49 AM
rudecat's Avatar
rudecat
I have a brand new Mini Cooper and I noticed that there is some kink of clear oil leaking out of the hole on the bottom middle of the hatch door onto my rear bumper. Has anyone else had this problem? Is the door missing a seal?
Old Jun 21, 2008 | 10:53 AM
Guest's Avatar
Guest
Is it possible that it's water leaking out of one of the drain holes? Maybe it's picking up residue on the way down the drain making it "Oily". I don't think there are any parts in the rear that use clear oil for lubrication.
Take a picture maybe of where it's leaking from.
Old Jun 21, 2008 | 11:02 AM
rudecat's Avatar
rudecat
Thanks!
Thanks. I'll check out your theory and take a picture as soon as I can. I can't imagine that it could be anything serious from the location.
Old Jun 21, 2008 | 12:50 PM
Dark Knight's Avatar
Dark Knight
It is the protective rust proofing and wax that is used when it is shipped over. It will leak out for some time in the rear and around the front too. Windex will take off the residue and not hurt the paint. There are some other threads about this issue. Both my "S" and my wife's Clubman have the issue. Mostly since it has gotten really hot outside. The SA said it might leak for up to a year. I just cleaned off some the other day. I hope that helps.
Old Jun 21, 2008 | 01:16 PM
rudecat's Avatar
rudecat
That's a relief!
Thanks for the info. I feel better now. It's just one of many things they don't tell you.
Old Jun 21, 2008 | 06:58 PM
JudgeS's Avatar
JudgeS
Does it look like yellow grease, almost like egg yoke?
Old Jun 21, 2008 | 08:13 PM
drtdvl's Avatar
drtdvl
what I have observed is a yellow grease-like substance coming from the same area. There is a thread titled, Cosmolene which I think is the same thing.
Just now need to google "Cosmolene" to see what it is.
Old Jun 21, 2008 | 08:25 PM
JudgeS's Avatar
JudgeS
Searched it, comes off best with Mr.Clean magic eraser, may take some time before it actually stops.
Old Jun 21, 2008 | 10:54 PM
rudecat's Avatar
rudecat
Substance
It's not a yellow thick substance. It's clear and very thin. Just has an oily feel to it.
Old Jun 22, 2008 | 05:43 AM
pilotart's Avatar
pilotart
Your windshield washer fluid is plumbed back to your rear window washer, being soapy it could also pick up additional characteristics if it leaked at rear wiper assembly and ran through inside of Boot Hatch.
Cosmoline is sort of a waxey/greasey material and would prevent corrosion.
Old Jun 22, 2008 | 10:51 AM
rudecat's Avatar
rudecat
Thanks!
Thanks. That's probably it if it isn't cosmolene. I'll just keep an eye on it. Hopefully it will stop.
Old Jun 22, 2008 | 11:44 PM
Ken G.'s Avatar
Ken G.
I'm getting the same stuff from both the boot and the bonnet, but only on hot days. I would concur that it's an anti-corrosion grease that's used on the cars when shipped from overseas. It's not cosmolene in the classic sense, since that stuff's really thick, brown and difficult to remove. The stuff in my Mini is actually quite easy to clean up and I'm not bothered by it at all. After the second heat wave here in San Diego (over 90 degrees F for a total of 10 days) the grease has stopped coming out.
Old Jun 23, 2008 | 11:27 AM
rudecat's Avatar
rudecat
Thanks!
Thanks. That confirms what other people have told me. I'll stop worrying about it. I already think is may have stopped. I'm in Sacramento and it's been really HOT here lately as well.
Old Jul 6, 2008 | 08:59 AM
dhoosee's Avatar
dhoosee
Yes, I'm getting it leaking from beneath my rear wiper, onto the chrome trim, and then the boot. Must be coming from the wiper assembly itself.
Just had white sport stripes installed yesterday, and it leaked onto the new white stripe. I cleaned it up with some degreasing cleaner, then put a light coating of wax on the stripe to help keep it from staining.
Guess I'll just keep wiping and cleaning until the (grease/cosmoline) well runs dry!
Old Jul 6, 2008 | 09:43 AM
Ken G.'s Avatar
Ken G.
I've also been getted that from the rear wiper. Seems to have stopped for me. BTW: Love the name Onslow, we're big "Keeping Up Appearances" fans.
Old Jul 6, 2008 | 10:17 AM
dhoosee's Avatar
dhoosee
Thanks, Ken!
Don't know a lot of people who have seen or know of K.U.A., but I'm glad that you get it!
I'll be "christening" Onslow shortly (once I get the vanity plate and new wheels put on). This will entail a blast to the boot with a can of shaken-up Boddington's followed by a hail of crumbled crisps (or Jays potato chips, since I cant get true English chips here in Illinois). I really think that the sloppiness of it all will capture the true spirit that is Onslow. I'll video the event and post soon. Hopefully, by that time, the greasy goo running from the rear wiper will have stopped, and I'll be able to keep it clean from that point on.
Old Jul 6, 2008 | 05:14 PM
Ken G.'s Avatar
Ken G.
We can only hope your Onslow moves faster than the other Onslow!
You should get a MY Mini and call it Daisy.
Personally, I like pawn cocktail crips and a good Guiness, but a Boddie's is a close second. If you really can't find British crisps, PM me, I have a place that has them here in SD.
woodstudio
Mar 15, 2020 08:28 AM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
ShadyCoop
Aug 24, 2015 06:05 AM
azntaiji
Aug 13, 2015 03:24 PM
