R56 Heat and sunroof sticking
Old Jun 18, 2008 | 07:47 PM
rmt27's Avatar
rmt27
For those of you not following the weather on the east coast, it's been d*** hot the last couple of weeks. This has been causing a problem with my sunroof. After it's been sitting in the sun for at least an hour in 93+ heat this happens. If the roof is closed and I hit the toggle for it to crack automatically, it will move about a quarter of an inch max, and then return to the closed position. If I hold the toggle to open, it does the same thing repeatedly until I let go. If it's been open in the sun, it closes fine.
Anyone else?
Old Jun 18, 2008 | 07:54 PM
jjp007's Avatar
jjp007
https://www.northamericanmotoring.co...56#post2310356
and another long long thread here about this problem
https://www.northamericanmotoring.co...d.php?t=137737
Old Jun 18, 2008 | 11:33 PM
Ken G.'s Avatar
Ken G.
I'd like to ask question that doesn't seem to have appeared in either of these threads.
When you try to open the top and it sticks, does the glass seem to stick to the rubber seals, or does it move off the seals, then stops and reverses?
Old Jun 19, 2008 | 12:02 AM
jjp007's Avatar
jjp007
If I remember correctly that is covered in that last thread. Someone lubbed up the rubber seal to see if that would help. I dont' think it did.
Old Jun 19, 2008 | 06:25 PM
Ken G.'s Avatar
Ken G.
I missed seeing that, so much for my speed-reading skills.
Old Jun 19, 2008 | 08:54 PM
e30r56's Avatar
e30r56
Mine's the complete opposite. If it's left vented in the sun all day, and I try to close it, it just pops right back up until I open it all the way a couple times.
Old Jun 20, 2008 | 09:15 PM
Ken G.'s Avatar
Ken G.
Kinda sounds like there's something expanding to the point that it jams the lift mechanism. Who knows??? It would be interesting to see what the installation looks like.
Old Jun 20, 2008 | 09:33 PM
DragonWagon's Avatar
DragonWagon
RMT, your profile doesn't list where you live, so we can't compare how f'ing hot it is out there.
Some day, we'll all find out what's causing the sunroof problem. There's a bunch of threads on this.
Old Jun 21, 2008 | 12:52 AM
daffodildeb's Avatar
daffodildeb
Can't speak for others, but mine definitely does NOT stick to the seals. It moves about 1/4" and then stops. Now that the weather is hot, it's started doing it again. A friend's '08 is doing it, too, only his is doing something with the tilt function.
BTW, here's another thread, one that I started: https://www.northamericanmotoring.co...d.php?t=139480
Old Jun 21, 2008 | 03:22 AM
Corey986's Avatar
Corey986
OK, it's not the seals...
Princeton Mini wrote on my service report, "CURRENTLY UNDER INVESTIGATION BY BMW NA"
who luckily are located in NJ in a brand new building with no tree coverage, so I'm guessing they have reproduced it and just don't know how or why to fix. I would expect to have a TSB as soon as they figure this out...
Old Jun 21, 2008 | 04:26 AM
DrewN's Avatar
DrewN
Just to play devil's advocate -- I haven't observed any sunroof issues, and we're in the same area Corey. However, best of luck to you, hope everything turns out OK
Old Jun 21, 2008 | 06:00 AM
JudgeS's Avatar
JudgeS
Having it happen to me, I definitely think its something sticking do to the heat, and not a motor issue. The behavior is very similar to pinch protection on power windows.
Old Jun 21, 2008 | 06:03 AM
JudgeS's Avatar
JudgeS
Corey, keep us posted, I'm not going to have anything done about this till there is a TSB and a clear remedy, its a minor issue, easily fixed by just pushing up on the rear glass when you go to open. Princeton is my dealership as well, so its good to know they are aware of the issue.
Old Jun 21, 2008 | 08:09 PM
daffodildeb
Super! Keep us informed, will ya?
Lex2008
How to
47
Jun 15, 2022 06:18 AM
rbarakat
Oct 3, 2015 11:08 PM
Accessory Products
Sep 10, 2015 11:38 AM
Gen1Parts
Sep 7, 2015 01:37 PM
