R56 Optimum tire size for 16 inch rims
Old Feb 22, 2008 | 06:07 AM
army scope jockey's Avatar
army scope jockey
After trolling the board for a couple mos, I pulled the trigger on an 08 Cooper S. I went with the 17 inch crowns with the run craps all seasons. My plan is to use them for winter duty.
So I want to go with a set of 16 inch (probably Rota RBs) for summer use. What is the best size for normal driving? I am in Germany so that means Autobahn runs. The Mini is for my wife so it will not get too flogged. I seen 205/50/16 and 205/45/16.
Anyone bought from these guys?
http://cgi.ebay.com/ebaymotors/ws/eB...212346187&rd=1
Old Feb 22, 2008 | 06:12 AM
th3118's Avatar
th3118
Coordinator :: Dynamic MiNi Collective
You'll get a lot more info on tires in the Tires, Wheels, & Brakes forum:
https://www.northamericanmotoring.co...splay.php?f=36
Old Feb 22, 2008 | 11:35 AM
PistWalrus's Avatar
PistWalrus
A 215/50R 16 would give you just about the exact same overall diameter as the stock 195/55r16 and still give you more rubber on the road. A 215 will fit just fine on the stock rim, I've got second set of stock 16's for Auto X that I put 225/45r16's on, they are a bit wide but still fit well. 215's would look great!
Old Feb 22, 2008 | 12:04 PM
Robin Casady's Avatar
Robin Casady
I'm running Pirelli P-Zero Nero M+S (all season) 205/55ZR16 on Rota RB 16x7 wheels. Their O.D. is about 0.4" larger than stock. As a result, the built-in error in the speedometer is diminished. The rpm per mile is 836 which is about 2% less than the stock Dunlap SP Sport 01 DSST 205/45ZR17 that came on the original Crown Spoke 17x7s that came with the car.
Edit: Pirelli P-Zero Nero M+S 205/50ZR16 are about 0.4" smaller than stock O.D.
Old Feb 22, 2008 | 10:17 PM
army scope jockey
Any problem using TPMS on the Rota RBs? I have a BRG mini and was thinking of going with the gun metal 16s. I guess they could be powder coated to match the car, right? Also I assume the RBs are hub centric for the new R56.
Old Feb 23, 2008 | 10:43 AM
Robin Casady
I have the older rotation speed based system TPM system, so no sensors.
However, I hear that the sensors will fit on most wheels. I have the Royal Silver color and it is some sort of paint or powder coating. You would have to have that stripped, I think.
Old Feb 23, 2008 | 01:15 PM
JohnnyF's Avatar
JohnnyF
I don't recall when the TPMS switched systems but there are some threads around here if you search.
Off-topic: If you do the gun metal RBs on the BRG, please take some pics. I'm thinking about the same setup.
Old Feb 23, 2008 | 01:25 PM
ENGINE 58's Avatar
ENGINE 58
i would like to run this 16x7 wheel with 225-50-16 tires
Old Feb 23, 2008 | 01:26 PM
ENGINE 58's Avatar
ENGINE 58
sorry im not good at posting stuff
Old Feb 23, 2008 | 01:27 PM
ENGINE 58's Avatar
ENGINE 58
16x7 with toyo 225-50-16 t1r for the street. judging by the specs that tire should fit that rim.
Old Feb 23, 2008 | 02:19 PM
jw34's Avatar
jw34
They were switched starting with the some August 07 builds.
Old Feb 23, 2008 | 02:45 PM
ChiliXer's Avatar
ChiliXer
Yeah I like the 215 size. Good optimization of rim and handling without getting too far, plus keep the speedo as accurate as it was when you got the car at least.
kazyn
Oct 25, 2019 02:34 PM
FLYM1N1
Oct 13, 2015 04:33 PM
Colt45Magnus
Sep 7, 2015 10:47 PM
TOMSR53
Aug 26, 2015 10:18 AM
col127
Aug 21, 2015 02:11 PM
