R56 I feel terrible...
Old Aug 24, 2007 | 08:11 PM
  #51
ScottRiqui's Avatar
ScottRiqui
Originally Posted by dirkinoff
I am actually not wrong unless you live on another planet! The weight of the rotating mass will pass the rev limiters cut off point, it will continue to accelerate because of the weight of the rotating mass I.E. crank, flywheel, rods and pistons ETC. until the energy is expended and then it will start its decent and then bounce of the limiter. Stop and think about what you are saying "The rotating mass will immediatley lose its energy because the rev limiter kicked in and stay at that rpm, even though it was accelerating in its rotation?" There will be a brief period of time when the inertia of the rotating mass as it "spins up" will pass the rev limiter. P.S. I am glad you do not work on airplanes! Have a nice day and enjoy the flight
Of course the rotating mass doesn't immediately lose its rotational kinetic energy - I never said it would. But the instant the rev limiter cuts in, that rotational kinetic energy *stops increasing*. Since the rotational kinetic energy is equal to the rotational inertia (which is constant) times the square of the rotational velocity (KE= I times omega squared), that means that when the kinetic energy stops increasing, so does omega (the rotational velocity). That means that once the combustion stops, so does the acceleration of the rotating mass. It keeps moving, of course, but it's not going to *speed up* once combustion stops.
Or here's a slightly shorter way of explaining it -- At the instant the rev limiter kicks in, the rotating assembly has a kinetic energy determined by its rotational inertia (which is a fixed value) and its rotational velocity. The rotational velocity cannot increase any further unless *more* kinetic energy is added to the system. With no more combustion (since the rev limiter has kicked in), where exactly are you claiming that this additional kinetic energy comes from? Look at the formulae and do the math, and you'll find the answer.
Claiming that the kinetic energy that's already present in a rotating system will somehow cause the velocity to increase without any additional energy being added is silly. Because what would happen if the rotational velocity *did* increase, as you're claiming it will? The kinetic energy must then increase, since kinetic energy increases with velocity. Well, since there's even *more* kinetic energy now, the velocity must increase even further, right?, which leads to more kinetic energy, more velocity, more kinetic energy, more velocity, etcetera etcetera. All without any combustion taking place in the cylinders. Congratulations! You've just created a perpetual-motion machine!!
Old Aug 24, 2007 | 08:52 PM
  #52
mufflethis's Avatar
mufflethis
Woohoo!!! No more paying for gas!!!!
Old Aug 24, 2007 | 09:01 PM
  #53
r56mini's Avatar
r56mini
f=ma. a=f/m. a=v^2/r. there is no way we can protect the engine with one oil change every 16K miles!
Old Aug 25, 2007 | 07:44 PM
  #54
dirkinoff's Avatar
dirkinoff
Ok, Ok I'll admit it I was wrong, very wrong, Now lets never speak of it in public again, All kidding aside thanks for the great E-mail it was very informitave. And one more for the record I was wrong.
Old Aug 26, 2007 | 02:04 AM
  #55
khor01's Avatar
khor01
Originally Posted by Bhatch
Missed down shifts will over rev the engine, no electronics can stop it. You did not no damage with that shift, but if you had put it into 2nd you would have nothing left.
I accidently dropped into 2nd from 6th (instead of 4th) while doing 85mph in my bimmer.
I quicklky realized my (absolutely horrendous) error and put it in neutral. It bounced on the rev limiter and sat there for about 2 seconds, and then normalized.
This was at ~1500 miles. I am now at 19K miles and have had no problem... Good thing it's a lease though, and I don't plan on keeping it in case my 2nd gear fiasco caused damage.
Old Aug 26, 2007 | 07:55 AM
  #56
Kasey's Avatar
Kasey
Yeah, I had a Saab Turbo about 10 years ago and was accelerating very hard with the stereo on very loud (yes there is a story here, no you can't hear it) and missed 4th, went to 2nd instead.
I didn't know I had missed it and still was on the gas. It took me several seconds to realize I had hit the rev limiter.
I could feel the loss of power and glanced at the tach and it was bouncing up to red line, then falling to almost nothing, then bouncing right back to red line.
I drove it for 50k miles after that before I moved on to something else and never had any trouble. Probably the most reliable car I ever owned.
I wouldn't worry.
Old Aug 26, 2007 | 04:19 PM
  #57
MotorMouth's Avatar
MotorMouth
You are correct, And when rotating weight is being "spun up" at a very quick rate it will keep increasing in speed until the energy in its rotating mass is used up, What do you think the flywheel is for? When you step down quickly "not slowly" on the accelerator pedal and the tach needle passes the red line it is caused by the rotating weight and inertia, The needle does not just stop at the rev limiter cut off.
Originally Posted by MotorMouth
are you saying that if you remove the force that is causing acceleration to a mass that the mass will continue to accelerate for a short time?
I'm sorry. I don't believe that.
I think some guy wrote a law about bodies in motion and external forces or something that may have a play in this. ( not that it was a particularly smart guy >g<)
Of course the rotating mass doesn't immediately lose its rotational kinetic energy - I never said it would. *snip*
Thanks Scott. I think he gets it now =)
Old Oct 2, 2007 | 05:02 PM
  #58
MC40S's Avatar
MC40S
3rd hard to 2nd
ok what about 3rd at almost redline to 2nd? how badly would that hurt the car? early 04 S lets say.
Old Oct 3, 2007 | 09:12 AM
  #59
bluesmini's Avatar
bluesmini
it will not hurt the car.........
Old Oct 3, 2007 | 11:27 AM
  #60
MC40S's Avatar
MC40S
I was just worried about the valves. there was no smoke and i didnt smell any burning clutch but i just really worry about my car since i love it so much. how high can it run without being hurt?
Old Feb 7, 2008 | 09:20 PM
  #61
Fei's Avatar
Fei
Ouch, I couldn't believe that I did this tonight on highway. I mis-shifted into 2nd gear from 3rd gear around 6000rpm, and I saw the engine was over-reved to 8000k rpm perhaps. I did clutch in the second after I saw the rev bottomed.
Any damage on synchro or engine? I didn't feel anything yet and it was very cold outside.
Old Feb 7, 2008 | 10:34 PM
  #62
bluesmini's Avatar
bluesmini
if it doesn't start making bad noises right away your fine.
Pker
Apr 11, 2017 12:14 AM
wildwestrider
Dec 27, 2015 08:20 PM
IrishMCS
Dec 1, 2015 04:21 PM
bmanrkg3
Sep 18, 2015 12:11 PM
Suspension Products
Sep 10, 2015 11:46 AM
