R56 I feel terrible...
Old Aug 23, 2007 | 09:51 PM
  #26
Robin Casady's Avatar
Robin Casady
Originally Posted by BlueBonnet
Much ado about nothing. Nowhere near the red line. So, how does this thread survive. Must be some shared guilt for past misshifts.
Much ado About Nothing has survived for over 400 hundreds years. Not surprising this thread has lasted the evening.
Old Aug 23, 2007 | 09:52 PM
  #27
daffodildeb's Avatar
daffodildeb
Originally Posted by mufflethis
Edit: And if overreving happens to anyone and the car seems to drive fine it would still be a good idea to take it in for service tell the service people what happened and have them check the engine. You might have bent push rods and won't know until your engine blows up a couple months down the road.
Boy, that's the last thing I'd want to tell them! If it blows, it blows--no sense letting them know in advance I'd screwed up, eh?
Old Aug 23, 2007 | 09:59 PM
  #28
mufflethis's Avatar
mufflethis
They'll know anyway. All they need to do is check the ECU.
Old Aug 23, 2007 | 10:01 PM
  #29
daffodildeb
What exactly does the ECU show? A rev over redline? Highest rpms reached?
Old Aug 23, 2007 | 10:06 PM
  #30
BlueBonnet's Avatar
BlueBonnet
Good Point!
Old Aug 23, 2007 | 10:16 PM
  #31
mufflethis's Avatar
mufflethis
Probably the highest RPM, I'm not sure about the MINI but with other cars it's highest RPM. There might be a limit though for example with the BMW M3 it will show the RPMs up to 8260 or something like that, not totally sure about the number.
You just have to make sure that if it blows it takes out the ECU as well.
Old Aug 23, 2007 | 11:15 PM
  #32
msh441's Avatar
msh441
OK... tried it:
4000RPM + 4th gear = 70MPH.
shifted into 3rd... 70MPH + 3rd gear = 5100 RPM.
Waaaaaaayyyyyyy below redline, transmission tolerences or rev limiter... so, I agree again = non-issue.
Old Aug 23, 2007 | 11:26 PM
  #33
Green Goblin's Avatar
Green Goblin
I think it tells them everything that you've done I was at the car show at BMW North with ya'll a couple days ago since you know my supercharger has been replaced under warranty they checked the key and it came up good so the service advisor said your good to go you've been good with your car and it got fixed so I'm guessing it tells them average speed, rpm, and how fast the cars been....
Old Aug 23, 2007 | 11:29 PM
  #34
mufflethis's Avatar
mufflethis
Originally Posted by msh441
OK... tried it:
Good now we need someone to test if 7500 RPM will toast the engine to answer Robin's question.
Old Aug 24, 2007 | 12:14 AM
  #35
ScottRiqui's Avatar
ScottRiqui
Originally Posted by dirkinoff
I dont want to sart anything here but your rev liter does not know if you are upshifting ,Downshifting or in neutral. It works when the engine RPM passes a certain RPM some Rev limiters drop spark and some drop the signal to the fuel injector. Usually in the firing order of the engine to help slow it down. What your describing as a "money" shift can happen on a aggressive missed upshift just as easy as a missed down shift. I use the word aggressive as in really wringing it out! What happens is the rev limiter does kick in but the rotating inertia carries far over the red line and in some instances will cause a piston to valve collision because the valve spring cannot close the valve quick enough to miss being hit by the piston, Almost as if you have broken a timing belt. This problem was common on the E36 BMW M'3's.
Actually, inertia alone can *never* cause engine RPM to increase. Once the rev limiter removes the spark and/or fuel, the engine RPM will no longer increase - not even a little bit.
What *can* happen is that if there is a delay between when the engine reaches the limit RPM and when the limiter actually kicks in, the engine speed will continue to increase during the delay, which could carry you slightly past the limit RPM, but as soon as the spark or fuel is cut, engine acceleration stops *immediately*.
So while you're accelerating in one gear (or revving the engine in neutral), the maximum RPM you can possibly reach is the rev limit, plus a little bit more from the limiter delay. But if you downshift too far, the engine speed will go up to whatever the lower gearing demands (or until parts start to bend/break). In the case of a heinously-stupid downshift, the only thing that may save you is if your clutch or tires start slipping.
Old Aug 24, 2007 | 04:37 AM
  #36
Bhatch's Avatar
Bhatch
since the JCW Stage 1 a higher RPM limit (6500?) with the same internatls i am sure that 7000 k would not be a issue if you sliped the clutch in on time.
Old Aug 24, 2007 | 10:19 AM
  #37
surfblue's Avatar
surfblue
Me too
DDeb...I've grabbed too low a gear a few times. I'd bet that our reactions were similar. You immediately made a move to a higher gear, and I mean PRONTO. I've ground the gears a few times, too, due to rather sloppy clutch use while cruising the backroads. I don't think there's anything to think about here, other than to try and avoid it in the future. Don't lose sleep over it.
...horrible, in fact. Anyone know what 3rd gear RPM is when 4th is 4000? I was passing a truck and went for 5th gear--but grabbed 3rd by accident. Not a good feeling. I caught it quickly, of course, but it had to be up there.
Anyone know?
Old Aug 24, 2007 | 10:36 AM
  #38
dreman's Avatar
dreman
Well if it makes you feel any better, i went from 6th to 2nd, going about ~60mph. I was going for 4th, but missed
Old Aug 24, 2007 | 10:41 AM
  #39
daffodildeb
Now THAT'S a real owwie!
Old Aug 24, 2007 | 10:49 AM
  #40
dreman's Avatar
dreman
yeah, it was during break in period as well probabily the week after i got the car, and I was going into a pass. I think I might have reached 6k rpm. Shouldn't be too bad.
Old Aug 24, 2007 | 12:43 PM
  #41
chows4us's Avatar
chows4us
Not sure what MINI stores but other car makers store rpms.
Old Aug 24, 2007 | 04:49 PM
  #42
nrc's Avatar
nrc
That's incorrect. Once spark and fuel are cut off the force of the car will continue to act through the drivetrain to turn the crank at whatever speed it needs to turn to match the speed you're going in the gear you've stuck it in. The engine becomes an air pump, sucking in air and pushing it out the exhaust.
Because of the restrictiveness of the engine as a pump it will generate a good deal of braking force (which can create problems of its own), but if you shift to a low enough gear at speed it will overrev the engine.
Old Aug 24, 2007 | 05:05 PM
  #43
ScottRiqui's Avatar
ScottRiqui
If you read the rest of my post, I said the exact same thing - stupid downshifts *will* cause the engine to over-rev, and there's nothing the limiter will do to help you.
The post I was responding to said that in the case of a missed *upshift* (getting neutral by mistake), the engine could continue to accelerate *past *the rev limiter because of the "inertia" of the engine. That was the error I was correcting.
Leaving the car in one particular gear and trying to accelerate past the rev limiter, or simply revving the car in neutral will *not* cause the engine to exceed the hard RPM limit of the rev limiter.
Re-read my post. You're absolutely correct - if you're at redline in 5th and accidentally downshift to 2nd and pop the clutch, the engine will certainly over-rev, past the rev limit and all the way until parts start breaking.
Old Aug 24, 2007 | 05:26 PM
  #44
r56mini's Avatar
r56mini
You quoted a statement that was correct and you started your sentence with "Actually.....never...." That was wrong, IMO. I stopped reading after that sentence because you sounded wrong.
Old Aug 24, 2007 | 05:28 PM
  #45
r56mini's Avatar
r56mini
You were done breaking it in then . I hope your engine doesn't burn oil as it ages.
Old Aug 24, 2007 | 05:34 PM
  #46
ScottRiqui's Avatar
ScottRiqui
Well, I thought the context of my post was pretty clear, since I quoted Dirkinoff's post before adding my reply, but I guess to be explicitly clear, I should have said "the rotational inertia of the engine alone will *never* cause the RPMs to increase after the rev limiter has removed the spark and/or fuel".
If you look at Dirkinoff's post, he was claiming that if you missed an *upshift* and ended up flooring the car in neutral, that the engine RPM could continue to increase even after the rev limiter has activated, because of the inertia of the moving engine parts. That's 100% wrong, and that's the statement I was addressing in my post.
Old Aug 24, 2007 | 05:40 PM
  #47
r56mini's Avatar
r56mini
I am sorry... Now, I re-read the posts and you are correct.
Old Aug 24, 2007 | 06:44 PM
  #48
cnolan
So, you think 7500 rpm would toast the engine?
Not on my S2000 :-)
Old Aug 24, 2007 | 06:52 PM
  #49
r56mini's Avatar
r56mini
But if we raced in an event where you cannot rev above 3500 rpm, your S2000 would not stand a chance against the MCS!
Old Aug 24, 2007 | 07:43 PM
  #50
dirkinoff's Avatar
dirkinoff
I am actually not wrong unless you live on another planet! The weight of the rotating mass will pass the rev limiters cut off point, it will continue to accelerate because of the weight of the rotating mass I.E. crank, flywheel, rods and pistons ETC. until the energy is expended and then it will start its decent and then bounce of the limiter. Stop and think about what you are saying "The rotating mass will immediatley lose its energy because the rev limiter kicked in and stay at that rpm, even though it was accelerating in its rotation?" There will be a brief period of time when the inertia of the rotating mass as it "spins up" will pass the rev limiter. P.S. I am glad you do not work on airplanes! Have a nice day and enjoy the flight
