R56 Display the VIN/Build Date On Tach
How to unlock test menu!
"Test functions of the instrument cluster
The test functions are displayed in the LC display of the instrument cluster.
The test functions are used in service to check the coding. The test functions are also an aid to troubleshooting without the BMW diagnosis system.
Starting the test functions
Locking and unlocking the test functions (test function 19)
Only the first two test functions are freely accessible. As of the 3rd test function, all other test functions are locked. Unlocking is only possible using test function 19. The test functions are unlocked by entering the total of the vehicle identification number."
- Terminal R On or terminal 15 On
- Hold down the reset button in the instrument cluster for 10 seconds
Not exactly sure what they mean by the "total of..." - presumably it is the numerical summation of your VIN digits (probably just the last 5).
NOTE: I have not tried this myself yet and I assume no liability if you manage to unlock your's and brick your car's computer!
First off thank you TheBigNewt for that discovery and starting this thread
I printed the single post instructions on how to access the information and tried it on Scrappy yesterday and it worked great.
The important information-
Production Date: 2/27/08
S/W Version: 78.52.00
The rest of the information culled from the test I really didn't have much need for personally.
The only thing is that by pressing the odo reset button during the test/information procedure sets it back to 0.But I always log the current mileage on all of my gas receipts so I can calculate my MPG per fill up.
I just discovered this interesting tidbit in the MINI Wiring Diagram System under the "Instrument Cluster" section. Note the last sentence:
More info...
From a BMW forum:
On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
Oh, and just to confirm how to unlock the menu:
Add up the last 5 digits to get the "unlock code", e.g. the unlock code for "AB12345" would be 15 (1+2+3+4+5).
1.1 4nnn K-number
1.6 Not used
3 SI Data
9 Battery
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
16 Not used
17 Not used
18 Not used
20 Not used
00 End of test
Fuel gage insight
From a BMW forum:
1.1 4nnn K-number
1.6 Not used
3 SI Data
9 Battery
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
16 Not used
17 Not used
18 Not used
20 Not used
00 End of test
1.1 4nnn K-number
1.6 Not used
3 SI Data
9 Battery
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
16 Not used
17 Not used
18 Not used
20 Not used
00 End of test
Does anybody have any insight into the degree of symmetry of the MINI tank. Just playing with the example produced some interesting non-linear draw down curves.
I think that's the date the car was built in Oxford.
Here's the "Things you didn't know..." thread:
https://www.northamericanmotoring.co...ad.php?t=93485
it's a green and white computer printout that lists yr car's birth (build) date, that's all. It should stay with the car throughout the entire build/ship/delivery process.
Aside from the "gee whiz" factor, what practical value does accessing these computer hidden menus provide? Are there any settings that can be altered? If so, why would they be altered? Everyone seems excited by this discovery, but what use is it?
A DVD tour??? Wha??
As you can see in the thread I bought two and they were only $23. I looked at the site again it doesn't look like they are going for that cheap anymore. The rest were the same price as the are now, way too expensive. They did help me get through the 109 day wait I had on my ordered car.
How to unlock 19.xx
What a coincidence this thread is! Just this afternoon I also took 15 minutes and got into the CPU the same way and noted the many "empty" menus (after 1.xx and 2.xx, the rest do not display a name).
There are of course programmable menus there and the trick must be getting 19.xx to read "unlock" rather than the default "lock", as you say R56mini.
This is where we need some help from R50/R53 guys that played around with the CPU settings!
R50/53 Help please.. Odd issue.
PsychoRallye
21
Feb 17, 2019 06:08 AM
EVMini
Sep 28, 2015 10:20 AM
