R56 Rear fogs
Old Jul 25, 2007 | 11:21 PM
MiniSkim's Avatar
MiniSkim
Rear fogs
My MCS has all the toggles in place except for the rear fog lights. I am thinking maybe I can get them after the fact. Does anyone know if the dealer can put them in aftermarket and complete my toggle switch collection? I hate having one missing! Plus I do like the way the rear fogs look. Since I bought off the lot I didnt have a choice in the matter. I'll be sure to ask about it on Friday when I bring the car in to have the sunroof tightened. Darn wind noise! Thanks for the thoughts.
Old Jul 26, 2007 | 01:39 AM
mataku's Avatar
mataku
I made sure to get the full toggle panel on my order because I was reading something about the toggle panel being connected to the AC and Speedo and not independent like in the first generation MINIs. I'm sure you can get it done, but it might get expensive; hopefully I'm wrong. Good luck.
Old Jul 26, 2007 | 06:28 AM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
Yes, rear fogs can be added after the fact, in most states that is (here in Oregon it is illegal to have rear fogs as low on the vehicle as it is on the Minis). The dealer will have to reprogram the ECU after they get installed. So even if you do the install yourself, you'll still need to take it in to the dealer for the programming.
Old Jul 26, 2007 | 01:32 PM
radiospace's Avatar
radiospace
That's interesting. (But why?) Does that mean you can't order rear fogs through your local MINI dealer there, or that you'd get pulled over and issued a citation for driving one outfitted as such? What if someone moved to the state with the car, would they have to get the rear foglights removed?
Old Jul 26, 2007 | 01:45 PM
mf44's Avatar
mf44
The problem you'll run into is that the switch panel is part of the AC control panel, so the necessary replacement bits will probably cost you a decent amount. Otherwise, I'm told the fogs are pre-wired.
Old Jul 26, 2007 | 05:28 PM
SimpsonGI's Avatar
SimpsonGI
Correct, they legally cannot order or sell a new vehicle in Oregon with the rear fog light in the position it is for the Minis. When I originally placed my order I had ordered the rear fog light. When I got my order sheet to sign off on it, it wasn't on the sheet so I called my MA and he said they had to remove it from the order.
I had commented about this once before and Sowellman had the information handy and posted it to here on NAM. My comment was something to the effect about it being silly like how we can't pump our own gas here in Oregon.
I have seen out of state Minis in town with them. I'm thinking of getting one after-market and wiring it as a backup light since that was what I was originally intending it for anyway. I have some family that lives outside of town and it can get very dark out there. Any extra light while backing up would be helpful.
In regards to out of state vehicles getting ticketed for using them. I don't know.
EDIT: I did a quick search and I found the post I was talking about.
Old Jul 26, 2007 | 05:36 PM
SimpsonGI's Avatar
SimpsonGI
Here is the text of the rule.
735-108-0076
Mounting, Wiring and Aiming of Rear Fog Lamps for Motor Vehicles and Trailers
(1) Transportation Safety adopts the mounting requirements for rear fog lamps as follows:
(a) If one lamp is installed, mount the lamp on the left side of the motor vehicle;
(b) If two lamps are installed, mount the lamps symmetrically around the rear centerline of the motor vehicle;
(c) Mount the lamps the same height above the level ground as taillights are mounted;
(d) Measure the mounting height from ground level to the center of the lens of the lamp; and
(e) Do not mount the lamps so they interfere with required motor vehicle lighting.
(2) Transportation Safety adopts the wiring requirements for motor vehicle rear fog lamps as follows:
(a) Rear fog lamps shall be wired so they can only come on when the motor vehicle low beam headlights are on;
(b) A switch shall be installed so rear fog lamps can be turned off or on leaving the low beam of the headlights on; and
(c) A steady burning indicator light shall be wired so it comes on when the rear fog lamps are turned on and mounted in a location it is readily visible to the driver.
(3) Transportation Safety adopts the aiming requirement for motor vehicle rear fog lamp through a horizontal angle from 45 degrees to the left and right of the center of the lamp.
Stat. Auth.: ORS 184.616 & ORS 816.230
Stats. Implemented: ORS 816.230
Hist.: DMV 3-1997, f. & cert. ef. 1-21-97
valthun's Avatar
valthun
That is very interesting, guess I am glad that I don't live in Oregon anymore, granted I don't have rear fogs. But I have no problem with not being able to pump my own gas. It's kind of silly with the new pumps or when they force you to go inside and wait for your pump to be called in order to pay, but I still don't mind one bit.
Old Jul 26, 2007 | 11:04 PM
SEAL6's Avatar
SEAL6
So SimpsonGI at least from the sounds of the rule we could wire in our own so long as the don't act as "fog lights". Right?
If you get it done....you'll have to show us pics and tell me where you got it done at
Old Jul 27, 2007 | 06:23 AM
SimpsonGI's Avatar
SimpsonGI
That is my interpretation as well, yes.
Old Aug 21, 2007 | 05:33 PM
SuwaneeM3's Avatar
SuwaneeM3
Anyone have info?
So has anyone yet had fogs added after the fact? I called a dealer and they said it "could be done"... but that didnt sound too promising.
Anyone? Prices?
Also, anyone have clear lenses added after the fact? I'm sure the rears are easy, but do the fronts require lots of headlight pieces?
-s
Old Aug 22, 2007 | 05:06 PM
Pam's Avatar
Pam
This is a related topic but slight twist.....I just like the looks of having the rear fog lights in place. Don't think I would probably ever use them. Does anyone know if you can get just reflectors the size and shape that fit the customized cut-out place where rear fogs would be installed?
Old Aug 22, 2007 | 07:03 PM
soul embrace's Avatar
soul embrace
this was one thing i wish i had added to my MINI, i didn't even think about them till it was way to late. oh well it's an option i can live with.
Old Aug 22, 2007 | 11:35 PM
Robin Casady's Avatar
Robin Casady
You will regret not having them every time you follow yourself.
Old Aug 23, 2007 | 07:36 AM
maxshrike0's Avatar
maxshrike0
I love my foggies.... What can I say, I like lights...
Old Aug 23, 2007 | 06:04 PM
FLKeith's Avatar
FLKeith
I got to use my rear fog on the drive home after picking up my car. I drove through a typical Florida heavy summer storm so turned them on. My wife who was following said all she could see ahead of her were the rear fogs to show where I was.
Old Aug 23, 2007 | 11:06 PM
JeffreyC's Avatar
JeffreyC
Anyone? Prices?
-s
Rear fogs are about $39.00 each at the dealer. They didn't have a price on the toggle panel, but they did confirm that it is connected to the AC panel and would most likely be $$$. The parts guy did say that at some point Mini may release a retrofit kit to add the rear fogs, but that was just a guess.
Dec 23, 2015 10:36 AM
I_drive_slow
Aug 18, 2015 10:47 AM
Powershift
Aug 16, 2015 05:14 PM
