R56 R56 MCS: 1st racetrack impressions
On the inside of the car, things were about as uncomposed as the brakes. I'm not a big guy, and I was holding on for dear life within these vast plains MINI is calling seats. Way too wide, and way too shallow, the sport seats are no good for racetrack work. The R53 has the upper hand here; at least it wasn't madatory to change those sport seats! A few pluses however of the interior. The steering wheel feels good in my hands, and the shifter and pedals have good placement and are very easy to use. I guess the only issue I have in the interior is the seats lack racetrack support. Then again, keep in mind I'm used to Sparco's that are fit to my size.
Great write up. I've driven Gingerman several times with both my Audi B5 S4 & my NA Miata. Neither of them had any drivetrain modifications, but I once borrowed a Momo racing seat for the Miata. After that, I had modified stock seats with the seat cushion cut out to help get my helmet under the roll bar. I know what you mean about getting used to a race seat. It makes a HUGE difference. I'm curious how you think the stock sport seats in the R53 compare to the stock sport seats in the R56. Do you think they are any better? (my relatively limited experience from renting R53's left me underwhelmed at their support). Also, it is pretty common in the Miata community to keep a set of race seats in the garage and swap them for the stock for track events. Do you plan on doing this? (I realize that it is a lot more complicated due to the airbag issues).
Thanks!
Matt
My R56 JCW front rotors finally came in and I installed them. They are only about $100 each from the dealer. I hope this helps on track day. They are suppose to heat up and cool down faster plus allow the pads to outgas.
I have been looking for upgraded pads that will fit in the R56 front calipers. Anyone found any yet? I am looking for some like the Porterfield RS-4 pads that are good for street/autocross and track days, plus they are low dust.
I have been in contact with Tim at Porterfield and he has not been able to cross the OEM pads to any standard part number yet.
I could buy an OEM set for $125, send them to Porterfield and have them put the RS-4 material on them for another $150.
I think I will live with the dust for a while.
Ryan,
Great post ! I will be heading to Mosport with my R56 mid-July. I am not too concerned with the brakes at this point as I am a novice track driver and new to the MCS. I think I will be exploring my limits more than the car !
Quick question: I noticed the fog lamps (and access plug) are in direct line with the rotors. Did you ever consider removing them for the track ?
If you pulled the fog lights and cut a hole in the wheel liner and placed a airduct to connect the two openings, it would effectively cool the brakes. My 1991 318is has that setup from the factory. I don't know why today's cars don't.
