R55 HID headlight issue
Old May 27, 2023 | 10:06 PM
Rhart1's Avatar
Rhart1
HID headlight issue
Hello, I am looking to buy my first mini R55 but it originally came with HID headlights as an option. I cant afford to replace them since the actual assembly is broken. is it possible, even though they came from the factory with HID, to put in a cheaper, halogen version? they are listed on Rock Auto but i'm not sure they will work with the computer. I don't know much so any info would help. Thanks!
Old May 28, 2023 | 06:08 PM
Yoshimura 1's Avatar
Yoshimura 1
Get a used set from a pick and pull junk yard......
Old May 30, 2023 | 01:17 PM
Old ones that are good at a junk yard. Only other option for Xenons is what i did aftermarket and you swap over the old parts ( bulb and ballast) to the new one. So its just the housing. Older cars have to get the updated ballast design new or used, its marked below.
Option 1.
https://www.ecstuning.com/b-spyder-p...-yd-mc07-hid-/
Option 2.
https://www.ecstuning.com/b-spyder-p...-yd-mc07v2hid/
Options 3. Spyders style above but cheaper:
https://www.ecstuning.com/b-fk-parts...sbm016007~fks/
Old Aug 27, 2023 | 01:31 PM
WeaponizedaD's Avatar
WeaponizedaD
Updated ballast?
I feel like I just stumbled here and found the answer to my posted question about the different ballast designs. Is it as simple as getting the 3 screw ballast to replace the 4 screw?
Old Aug 28, 2023 | 07:23 AM
yep, you swap them out. their was an update to the ballast design in 9/2009 : *For MINIs with the older ballast pre 9/2009 you will need to use MINI part # 63117356250 ballast
BernieCoop
Feb 13, 2015 09:31 AM
Raze
Jan 22, 2012 01:50 PM
08pappy
Apr 5, 2011 10:30 AM
P200E
Aug 28, 2010 01:33 PM
eurazn
Apr 13, 2005 11:57 AM
