R55 Hey in need of some ADVICE. problems with mini!!
Hey y’all my name is Keith and I’m quite new here..
I have a 09 mini clubman s
ive been having constant overheating problems with the car
what I’ve done so far:
• replace thermostat housing
• replace water pump
• replaced coolant hoses
• did about 4 coolant flushes
I brought it to a Mini Cooper repair shop and they were great people.. BUT they can’t seem to find the problem. They suggest it’s a blown head gasket but then they sent it to a bmw shop to inspect it. They did inspection for only an hour(not much can really come from that because it wasn’t enough time to fully dive into it IMO) I’m just wrought with anxiety over my baby not running. The bmw shop said to replace engine and I don’t feel that be necessary because the car runs with no noises but just over heats and blows a little bit of white smoke. Can anybody give me some pointers. I was thinking about going to sneed for speed and purchasing a new cylinder head, arp header bolts, and a head gasket. Is there some thought her on my plan of action??
welcome to forum brother...
Minis have MLS head gasket and IMO, they dont "blow" perse! recently, i bought a thermostat housing and it seemed to have a new temp sensor. my fan kept running and the temp wasnt moving. at any rate, few things to check:
1- coolant temp, live data
2- coolant pipes properly connected
https://www.realoem.com/bmw/enUS/sho...diagId=17_0393
(manual transmission) https://www.realoem.com/bmw/enUS/sho...diagId=64_1555
(automatic transmission) https://www.realoem.com/bmw/enUS/sho...diagId=64_1593
3- does your fan run?
Do you get any codes on the scanner?
The fan does run on two different velocities. When the resistor goes bad, one of the two velocities either change to move slower or won't move at all. Try to check if you hear the speed of the fan changing when it becomes hot. Also, if the thermostat is aftermarket, it might have a bad temperature sensor, happens all the time. Switch back to the old sensor just to rule it out.
my car hasn’t sputtered or shut down. And the bmw dealership say to replace engine. As you know those (stealer)ships wouldn’t put in time to fully look into the problem so I decided to take things into my own hands. I was also thinking about buying a replacement head after I replace head gasket if that doesn’t seem to be the cure
secondhandr55 (06-05-2019)
Melly Fresh
01-09-2018 11:48 AM
mdrew0307
07-05-2017 11:37 AM
