R55 Battery Replacement Blues...my second and the window reset is listed by steps here
A repair shop replaced my battery.
The service tech did NOT put the two 10mm screws back to secure the battery compartment cover
Watch for that.
I had to reset the windows as the driver and passenger side windows would drop 1/2 inch when opening and not go back up when the door was shut
**EASY FIX**
Window Reset
1. Start the Mini
2. Roll all windows up and close the doors
3. Hold the driver side window button down and hold down 5 seconds after the window is down
4. Hold the same window button up and hold up 5 seconds after the window is up.
5. Open and close your door. The window should be programmed correctly
6. Repeat for the passenger window
Watch for that.
**EASY FIX**
Window Reset
1. Start the Mini
remotecontrol
04-01-2021 03:11 PM
timberwolf
11-14-2008 10:06 AM
diptenkrom
06-01-2008 09:05 PM
