R55 Mini clubman latch
Old 11-25-2018, 01:10 PM
avbrummie's Avatar
avbrummie
avbrummie is offline
Mini clubman latch
2010 mini clubman right rear door latch.
I took out the latch and tested the locking mechanism with a small piece of rod and it doesn't lock automatically.
Am I to assume I need to buy a new latch ?
Old 11-25-2018, 02:39 PM
I like mini clubman's's Avatar
I like mini clubman's is offline
From reading other posts it appears to be a problem area for clubbies. Someone with more knowledge hopefully will chime in. Try the search and see what you come up with.
Old 11-28-2018, 07:30 PM
EdsNotHere's Avatar
EdsNotHere
EdsNotHere is offline
If you have a latch that’s not working I’d replace both latches to avoid it not opening and then it’s a PIA to get open when the latch fails. I replaced both of mine when the left one failed.
Old 12-01-2018, 02:23 PM
mrbubba's Avatar
mrbubba
mrbubba is offline
My left side one has stopped working, although it coincides with the fuse box being replaced and also the rear wash wipe not working
Old 12-03-2018, 10:38 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
Yep do both at the same time, these are the two threads you need to do the job:
https://www.northamericanmotoring.co...arn-doors.html
DIY:
https://www.northamericanmotoring.co...4-clubman.html
Old 12-11-2018, 10:43 AM
CA94960's Avatar
CA94960
CA94960 is offline
Today my wife tried to close her right rear door and it wouldn’t latch, so she called me to help. I arrived and tried to get it to latch, but the door would not lock closed. I got some string for a store and tied it up so she could get home. Anyone have this problem before?
Old 12-12-2018, 08:27 AM
Did you manually do it with flat head screw driver on the mechanical latch side to test it. Using the screw driver as the fake striker hook.
Old 12-12-2018, 08:47 AM
CA94960's Avatar
CA94960
CA94960 is offline
I took it to our local independent Mini repair shop that does all the work I don’t know how to do and they said the right locking sensor needs to be replaced. It should be repaired by this afternoon.
Old 12-12-2018, 08:52 AM
Ok, let us know how it works out.
Old 12-12-2018, 09:08 AM
CA94960's Avatar
CA94960
CA94960 is offline
Thanks!
It’s my wife’s car and she needed to have it repaird by tomorrow so she can take it to work. She didn’t feel comfortable leaving it in a parking lot with velcro strap holding the doors closed, hence the quick need to have it repaired.
Svejk
02-24-2019 12:18 PM
Ministrater
10-02-2018 08:31 AM
Zommski
06-19-2018 08:50 AM
AutoMutt
05-11-2017 12:35 PM
Spank
MINIs and Minis for Sale (archive)
02-16-2008 11:39 PM
Quick Reply: R55 Mini clubman latch
