She drowned but recovery on the way - R55 Edition
After recovering this baby [[url]https://www.northamericanmotoring.com/forums/r57-cabrio-talk-2009/320889-she-drowned-but-recovery-on-the-way.html ], I got this poor clubman out of the swamps. I couldn't resist not getting it. it got some nice options non of my previous clubmans had. It arrived today after a long week of waiting...The fun shall begin ;)
https://cimg5.ibsrv.net/gimg/www.nor...0d5824cf47.png https://cimg5.ibsrv.net/gimg/www.nor...b89089a2b5.jpg |
After quick examination, I think this one comes with a pearl lol
The engine seemed to have been replaced recently. looking through the oil cap, the head still shines, the vacuum pump looks brand new, and the turbo oil feel line is still shiny. took the spark plugs out and no water is inside the cylinders. I will check the timing chain to see if it is the new edition and the air filter just in case, I'll leave the plugs out and hand spin it first. Few of the modules had some damage...FRM, JBE, MULF2, YAW sensor, and heated seats modules. I might also just replace the airbag module. I didnt check the TCM and the shifter but we'll find out once we get it started. the car came without keys, so i bought virgin keys and will try to mate them with the CAS once they arrive. stay tuned ;) |
Subscribed 😎
Not having a key, makes things a little slow...In the meantime, I took the ECU/CAS/keyfob from an 09 MCS with a manual transmission I have. I used a fuse box I was using on the 08 N18 swap and I used an FRM that was from another car..lol with weak batteries and a dying jumper box, I got the car to crank only! I read the codes and one stood out was the fuel pump activation fault. I didnt hear the pump priming or turning so I will try to test it after I use the right fuse box which i got today.
I wish I can find the original owner and ask him/her to send me the keys :sad: there was no trace of documents inside the car. https://cimg3.ibsrv.net/gimg/www.nor...ed656b1033.jpg https://cimg2.ibsrv.net/gimg/www.nor...fe98139b92.jpg |
After installing the right JBE, it started just fine. I was able to drive the car few feet back and forth. I let it run for some time and didnt notice anything abnormal. the CEL was on, of course, so I have to pull the codes and see what else the car is trying to tell me.
Because I need a key for this car, I figured I invest in a key programmer. I already have R270 to read the CAS eeprom. so i went ahead and got tango key programmer and virgin keys to mate. The blade can be cut fairly cheap and I can use the tools for the next project or if someone needs to add another key to their mini ;) stay tuned for more :) |
I like that clubby, did it get a fresh water bath or a salt water one? I always like working through a problem only to find a simple and cheap fix.
it doesnt have a strong odor. I believe it's fresh water bath. looking at the FRM module, the water seemed to reach 2/3 of it. so it wasnt that high...This would make my 5th flooded mini. but this the 1st that came without a key.
I got some time last night to clear codes and calibrate some modules...I let it purr for more than half hour :)
https://cimg6.ibsrv.net/gimg/www.nor...866cd89a1f.jpg |
Lookin' good!
Today is exceptional lol...I finally was able to get a keyfob programmed to the car. The days leading to today were restless. Here are few thousand words worth of pix :wink:
https://cimg9.ibsrv.net/gimg/www.nor...8fbb19fe08.jpg https://cimg4.ibsrv.net/gimg/www.nor...1f1bf4fdd5.jpg https://cimg8.ibsrv.net/gimg/www.nor...556c5cb930.jpg https://cimg6.ibsrv.net/gimg/www.nor...159c441360.jpg https://cimg7.ibsrv.net/gimg/www.nor...f0736bba85.jpg https://cimg5.ibsrv.net/gimg/www.nor...899a883614.jpg |
You are either extremely knowledgeable and competent or enjoy troubleshooting a submerged vehicle. MIni's are known for there electrical gremlins adding water fresh or salt will be interesting to see the outcome long term.
Originally Posted by hamptup
(Post 4436131)
Do you mind elaborating on the key coding?
I work mainly on minis, rebuilding n14s after chain failures, and even going as far as swapping a manual n14 out for an automatic n16. One of the main issues I have is providing spare keys for my customers. |
In a nutshell, you need the following:
1- R270 CAS reader. Extract the EEPROM 2- K-Tag ECU reader (if you have no keys, this is a must). Extract the Maps file 3- Tango key programmer. Use 1 and 2 or 1 and a matched key from the car to make a spare. 4- blank keyfob....NOT used. The details/how to are found in youtube. Yhe issue i have is with keyfob configuration. For instance, my lock button opens the trunk. The trunk button opens/closes the car. I have comfort access, the keyfob does not seem to activate the function. |
Cool, I like seeing the early MINI Nav display fro 2007-2011, so different than my 2011+ in the way the icons are. Glad is coming back to life.
(Post 4437131)
https://cimg5.ibsrv.net/gimg/www.nor...44a5757901.jpg https://cimg4.ibsrv.net/gimg/www.nor...cd0fbdfccc.jpg https://cimg6.ibsrv.net/gimg/www.nor...ec3e72702f.jpg |
Just bought a 2012 Clubman S
What is the software your using in photos ? Also what is FRM module ? Any advice on where to start for a flood car ?
Yea the 2011+ function and display is better based on what I like. Then of course it has the black trim which i perfer. The downside is a couple years ago MINI updated the display and removed the cool stuff like
Originally Posted by Spendy
(Post 4437168)
FRM is the footwell module or Body module that controls the lights and windows. if you have a flood car, start with knowing how high the water got. Then most likely, the modules submerged will need replacement. Fuse box is usually the door to everything in the car. |
Any updates on the outcome of this build?
Sure, the car is done. Everything has been installed, programmed amd coded. The only thing I'm doing right now is trying to program different keys to it. The first time i did it, the close and trunk functions were flipped...lol. I used another program to make it right, but instead lost connection to the key. I tried another one and some how the functions were spot on but it wouldn't start the car..lol i don't know how to configure the keys so it is a lot of trial and error.
I know i cam buy a key fob for 225 but I'm not ready to give up just yet. |
My 08 clubby has comfort access, where can a key fob be bought for 225?
Originally Posted by I like mini clubman's
(Post 4468759)
Thanks much appreciated. It gives me somewhere to start. I imagine I will need to take that fob to the dealer to be programmed?
(Post 4468878)
I have yet to get it fully programmed on my own! |
