R55 Wheelspin in first gear
Hey there fellow Clubby owners… I have found that my 2008 S Clubman has a tendency to peel out really easily starting from a dead stop in first gear. I'm not popping the clutch nor am I over revving the engine but I do have to slip it in a little bit to avoid wheelspin. I am currently running on a set of almost new Yokohama YK 580s. They have proper inflation and plenty of tread but have done this from the beginning. It is worth noting that my previous set of tires were very worn Walmart purchased Goodrides which also spun equally as easily but generally rode a little stiffer than these Yokohama's.
I guess what I am wondering is whether the Clubman is more prone to front wheel spin on acceleration due to having more weight in the rear than the R 56 which the suspension would have been normally designed for or is this indicative of some weak point in my suspension? I do believe I need to replace my rear struts which may be contributing to a little tail squat ( unconfirmed ) although it is not noticeable when driving.
Can’t find much information n those tires, but what I could find shows a high treadwear rating. This usually equates to a harder compound. A harder compound will give slightly less traction, and a greater tendency to slip. The Mini engines have a high amount of torque at lower engine rpms. Add all this up, and you have a greater tendency to “peel out.”
That's a good point! I got these with my wheels and figured "They're Yoko street tires with a pretty aggressive tread, so... But yeah, maybe they are a little too hard of a compound for the torque of the engine. My suspension is totally stock and could probably do with a little help anyway. Its all saving up the money to change it out afterall. :p
Seems like tire compound to me. You might take a peek at Tirerack and see what the ratings are for your version. Load rating and whether its H or V rated? They might be over inflated as well. Check your door jam and compare the inflation sticker to your actual readings. Best result when your tires are cold and than compare to heated tires after highway driving. Your PSI will change between the two. That range will be helpful when deciding what you like.
