R55 Yellow Half-Engine check light, codes...
Old Oct 11, 2016 | 04:26 PM
ThirteenthCurve's Avatar
ThirteenthCurve
Hey there everyone, just joined due to some issues I ran into with our Clubman S, which is the wifes DD. Hope to get these things resolved soon so I can go back to daily driving my Jeep and she can get her Mini back.
The car is a 2012 Clubman S with 26,000 miles on it. We just picked it up about 4 months ago.
Recently a "Service" light came on.
Then the yellow half-engine check light came on and it went into half power mode...no turbo in these cars really sucks!
I stopped at O'rileys and used their Bosch OBD2 scanner and pulled these codes,
1/12 - P0598 - Thermostat heater control circuit low - Confirmed
2/12 - P0031 - Heated oxygen sensor heater control circuit low bank 1 sensor 1 - Confirmed
3/12 - P0037 - Heated oxygen sensor heater control circuit low bank 1 sensor 2 - Confirmed
4/12 - P0003 - Fuel Volume Regulator Control Circuit Low - Confirmed
5/12 - P0598 - Thermostat heater control circuit low - Pending
6/12 - P0031 - Heated oxygen sensor heater control circuit low bank 1 sensor 1 - Pending
7/12 - P0037 - Heated oxygen sensor heater control circuit low bank 1 sensor 2 - Pending
8/12 - P0003 - Fuel Volume Regulator Control Circuit Low - Pending
9/12 - P0598 - Thermostat heater control circuit low - Permanent
10/12 - P0031 - Heated oxygen sensor heater control circuit low bank 1 sensor 1 - Permanent
11/12 - P0037 - Heated oxygen sensor heater control circuit low bank 1 sensor 2 - Permanent
12/12 - P0003 - Fuel Volume Regulator Control Circuit Low - Permanent
So, Im not very familiar with reading these, besides cross referencing charts. Not sure why the code reader shows the same 4 codes, 3 different times, with the only difference being "confirmed" "pending" and "permanent" noted below each code?
Secondly, anyone know whats up based on this?
I have an appointment to drop it off at the local shop tomorrow morning, but, Im curious. Lucky, I have an extended warranty. Unfortunately I have to front the diagnostics fee of $110 and wont get that back until after the warranty company deems the repairs covered.
Old Oct 11, 2016 | 04:38 PM
ThirteenthCurve
Some research I did,
P0598 - Thermostat issue. Most common fix was thermostat replacement.
P0031 + P0037 - Bad O2 sensor? or wiring? Not sure on this...
P0003 - HPFP? Perhaps battery issue?
I also noticed some weird issues with the car alarm randomly going off. perhaps the battery needs replaced and may be causing other issues?
Old Oct 11, 2016 | 06:58 PM
ThirteenthCurve
Update, found a blown 25amp fuse. Going to replace, once I find a 25amp fuse...of course I have 20 and 30's but no 25's
edit: replaced the 25amp fuse. Started her up, backed up, blew fuse.
Guess we'll see what the shop says tomorrow.
Old Oct 13, 2016 | 01:05 PM
ThirteenthCurve
First shop: Said the fuse was blowing because of a failed diode in the CPU, and had to go to MINI in order to replace it. So out $100 because the warranty service wont cover this as it needs to go to MINI to replace.
Took it to MINI of Seattle yesterday. I forgot to note the fuse issue when I dropped it off and just told them about the check engine issues and the codes. So they call me today saying they are replacing the HPFP and Thermostat. I asked about the fuse and they didnt say anything, so they have to go back and re-diagnose the issue...seems odd.
They ALSO found worn sway bar bushings and wanted $618 to replace those....warranty would only cover $450 some...no thanks. Ill do it myself.
And then they ALSO found "rat infestation damage" to the oil pump solenoid...which seems odd. I asked for more info here. After some quick research it sounds like this is a common leaky issue. The problem I have here is they are calling it infestation damage...and the warranty company wont cover it due to the "cause". That sounds like a line of BS to me!
Old Oct 18, 2016 | 08:53 AM
nkfry's Avatar
nkfry
When the oil leak from the control solenoid becomes bad enough the conduit around the wiring starts to deteriorate and fall off, not to mention; rats aren't big fans of petrol based products...
Depending on year and miles you may be able to have it covered under MINI warranty.
I would dispute the case, sounds like they're trying to get around the work.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
JPB660
R60/R61 Stock Problems/Issues
Nov 10, 2021 05:41 AM
TJANK
Jul 31, 2019 06:23 AM
Jonack
R59 :: Roadster Talk (2012+)
22
Nov 7, 2016 11:28 AM
Merv
Oct 25, 2016 09:07 PM
TJANK
Aug 10, 2016 11:46 AM
