R55 Yet another problem...the brakes?
Old Apr 14, 2016 | 09:39 AM
laurendesigns's Avatar
laurendesigns
Took the MINI out this morning and went to park it. All of the sudden the pressure on the brakes stiffened (best way to describe it) and the brake wouldn't depress fully. The car braked but barely. Took it for a spin in the parking lot and it did it twice. I couldn't fully brake, the pedal went about half way and stiffened. I know my back drivers side rotor is showing wear. Pads are fine on all 4. It also seems to be "stuttering" when fully braking.
Rotors? Calipers? Vacuum hose? I'm looking online and have seen a myriad of possible issues. Just wondering if anyone has experienced this and what to check for?
Old Apr 14, 2016 | 10:11 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
I'm thinking there is a possible vacuum issue here. I do know that signs of a faulty vacuum pump are things such as low brake booster vacuum, hard brake pedal, and brake fade during application when stopped.
888.280.7799 | 6am - 5pm PST
Old Apr 29, 2016 | 01:35 AM
neonsteve's Avatar
neonsteve
Did you check the brake fluid level in the reservoir? Are any of your pads worn down to the metal backing plate? You can peek at the outer pads at least with a flashlight looking through the wheel spokes. Just takes a few seconds per wheel. I don't know what your specific symptoms mean though...
Edit: Just noticed you did check pads...
quickcoop
Dec 4, 2020 09:05 AM
Buggy
Tires, Wheels, & Brakes
Jun 16, 2016 07:23 AM
Sstrickstein
Mar 23, 2016 09:28 AM
JWA
Mar 20, 2016 04:30 PM
Car Care Products
Mar 17, 2016 03:35 PM
