R55 Antenna roof seal dry rot and coming off
Old Nov 16, 2015 | 08:25 AM
WarEagle's Avatar
WarEagle
I've noticed the rubber seal that runs around the base of my roof antenna is dried, cracking and starting to peel off. I see that ECS Tuning has a lot of different seals and gaskets on their site but I couldn't find this one. Does anyone sell a replacement? Can I improvise a replacement?
Old Nov 16, 2015 | 11:45 AM
daddyandmadi's Avatar
daddyandmadi
Looks like the antenna base is pretty cheap. But I dont see just the gasket in the guide
http://www.realoem.com/bmw/enUS/show...diagId=65_1678
Old Nov 16, 2015 | 12:31 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
That seal is part of the antenna base so I don't believe you can get it separately. It's fairly inexpensive though. If you don't have nav or phone preparation it's 65203442105. If you do have nav or phone preparation it is a little more pricey and would be 65203456090. If you're unsure, you can give me your vin and I can get the right part for you.
888.280.7799 | 6am - 5pm PST
Old Nov 16, 2015 | 12:44 PM
What year do you have? MINI jumped around allot on the year and styles on the base. You cannot get that gasket separate though , just the whole roof antenna base.
Old Nov 16, 2015 | 01:28 PM
WarEagle's Avatar
WarEagle
2009 Clubman S, and I do not have Nav
Old Nov 16, 2015 | 01:34 PM
Yep, looks like you have the Sat. Prep one which is shared with the Nav one. You have that little wind bump on yours.
65203442169
https://www.ecstuning.com/Search/SiteSearch/65203456090/
Old Nov 16, 2015 | 01:54 PM
WarEagle's Avatar
WarEagle
65203442169
Any chance I can replace it with the cheaper base since I don't have the sat nav option?
Old Nov 16, 2015 | 01:57 PM
You could try the cheaper base gasket itself off the part, but I don't think it has the same form fit, looks like its close. , i guess its worth a shot. I just dont want water in there. If you do try it post back up. If you have the cheaper base you might loose a function
https://www.ecstuning.com/Search/SiteSearch/65203442105/
Old Nov 16, 2015 | 02:09 PM
WarEagle's Avatar
WarEagle
Thanks, I'll look into it. My wife has an 09 R56 and I may try and swap hers antenna base to mine and see if there is any issues. Any tips for how to remove the base? I know the antenna just unscrews from the base.
Old Nov 16, 2015 | 02:12 PM
Welcome,
Easiest way is to dip down the rear headliner , with the boot open and clip off the rear inside D pillars, then reach the screw on that antenna base. That's it.
Old Nov 21, 2015 | 12:10 PM
WarEagle's Avatar
WarEagle
Ended up carefully using a little bit of gorilla glue and got the seal gasket glued back to the antenna base. Going to see how long that lasts but if I need to replace the base I'll go with the sat nav base. My car does have satellite radio option which I'd like to keep for retail/trade in value.
Old Nov 24, 2015 | 06:24 AM
Thanks for the update, did you get gorilla glue on the paint, body or just the seal.
Old Nov 24, 2015 | 07:07 AM
WarEagle's Avatar
WarEagle
I applied it towards the bottom of the antenna base, there is a small gap between the base and the roof. Then I pressed the seal back into place. I didn't use much glue and it doesn't tend to drip so I think I kept it off the roof. I wasn't too concerned about the seal or the base since if the glue didn't work I'd have to replace them both anyways. But I'm happy for now.
Old Nov 24, 2015 | 07:19 AM
Just wanted to make sure you did not gorilla glue the antenna base to the roof, that stuff is strong and likes to bubble up.
Old Nov 25, 2015 | 12:03 PM
dolcemz's Avatar
dolcemz
I had a brain fart today and forgot to remove my shorty antenna before I went through a car wash. Resulted in breaking my antenna base. Before I order this, can you tell me if it's difficult to remove and replace?
2009 R56 JCW Hardtop...
65203442169
Old Nov 25, 2015 | 12:09 PM
Like posted above " Easiest way is to dip down the rear headliner , with the boot open and clip off the rear inside D pillars, then reach the screw on that antenna base. "
Mar 4, 2019 06:21 AM
Oct 29, 2015 07:52 AM
Oct 28, 2015 10:47 AM
Oct 23, 2015 02:26 PM
Oct 19, 2015 06:30 AM
