R55 Tire/ wheels
Old Oct 28, 2015 | 09:32 AM
KG-CMF's Avatar
KG-CMF
Tire/ wheels
Has anyone put 185/55 R16 tires instead of 195/55R16 run-flats ???, looking for something more narrow, better ride, fuel mileage....
Old Oct 28, 2015 | 10:04 AM
hsautocrosser's Avatar
hsautocrosser
It would appear the minimum load/speed ratings for a gen2 Clubman are 84H for anything other than winter only tires. I only see 83 load ratings available in that tire size. You'll lower your car 0.2" but that is within differences of factory OEM tires. That may decrease mpg a bit and make your speedometer error worse.
A low rolling resistance (LLR) tire will give you best fuel mileage but it will only be a few miles per gallon. Be aware that LLR also means less grip.
Non-runflats improve the ride substantially. Some tires ride better than others. Taller sidewalls ride better than low profiles. Your instant response to steering input will slow down a bit with non-runflats and taller sidewalls. The height of the sidewall is the sector width times the profile ratio. For example: 185/55-16 would be 55/100 * 185mm. A small increase improves ride and decreases handling a bit. The effect is greater on ride than handling.
TireRack.com provides a lot of test results and customer feedback on various tires.
205/50-16 and 205/55-16 are more common alternate sizes.
Last edited by hsautocrosser; Oct 28, 2015 at 10:36 AM. Reason: noticed the post is in the clubman forum
Old Oct 28, 2015 | 10:07 AM
MINIAC's Avatar
MINIAC
When replacing runflats with conventional tires most people plus-size to 205/50-16.
Old Oct 28, 2015 | 12:19 PM
SODA66's Avatar
SODA66
Tire Size
I put 195/60-16 on my clubman for the same reason. Better ride and it completely fills the wheel well. 195/60/16 is the tire size mini recommends for snow tires . So I just put all season 195/60/16 on mine and am happy with them.
Old Oct 28, 2015 | 01:35 PM
hsautocrosser
The Kumno Ecsta PA31 is highly rated and available in 195/60-16 for $78.
R55&R60_N18
Feb 17, 2016 08:18 AM
Nutter
Oct 29, 2015 08:45 PM
pwsull
Oct 27, 2015 04:49 PM
Lucas63
Oct 27, 2015 08:24 AM
jmward2008
Oct 25, 2015 03:42 PM
