R55 Tire pressure - 32psi on door what do you run, even wear?
Old Jul 27, 2015 | 02:09 PM
cargusjoh's Avatar
cargusjoh
Hi,
I have Conti pro contact runflat 195 55 R16 tires. When I got this car it had 37psi in the tires. I reduced that to 32psi per the door label. I searched and did not find answers to these questions:
1. Anyone get even tire wear at 32PSI, the recommended pressure (assuming rotating too)?
2. What pressure do you run and still have even wear (assuming rotating)
3. Why does 09 convertible stepdaughter has list 35PSI and my '12 clubman 32 psi? I have heard clubbys have softer springs, not sure it that is true and a factor.
Thanks!
Old Jul 30, 2015 | 07:49 AM
Pure Red's Avatar
Pure Red
I run the factory specs, and with 6,000 miles put on by me since late Jan, I'm ready to rotate the tires. I've already aligned my Clubman back in March, so between all those things, my tire wear is as good as I can get it. And is even.
Old Aug 6, 2015 | 06:32 AM
Jaque_Mate's Avatar
Jaque_Mate
I run 37psi...Because MINI, lol.
Old Aug 6, 2015 | 03:25 PM
timski's Avatar
timski
Originally Posted by cargusjoh
Hi, I have Conti pro contact runflat 195 55 R16 tires. When I got this car it had 37psi in the tires. I reduced that to 32psi per the door label. I searched and did not find answers to these questions: 1. Anyone get even tire wear at 32PSI, the recommended pressure (assuming rotating too)? 2. What pressure do you run and still have even wear (assuming rotating) 3. Why does 09 convertible stepdaughter has list 35PSI and my '12 clubman 32 psi? I have heard clubbys have softer springs, not sure it that is true and a factor. Thanks!
2011 JCW is 38 psi per the door label.
Old Aug 6, 2015 | 06:48 PM
danjreed's Avatar
danjreed
40 here. 38 is ok... but 40 seems to be good when its colder out... (Non run flats)..
Going down to 34, ride is much better, but car is not as much fun to drive... even less with non run flats. (factory 16" wheels..)
Old Aug 6, 2015 | 07:32 PM
yesti's Avatar
yesti
The continentals ride better with a little more air in them, which is the opposite of what you'd expect. Somewhere between factory recommended and max psi on tire minus 4-5 psi when cold should be good wear wise. Start at the top and let out 1 psi at a time till you find what you like.
Old Aug 9, 2015 | 07:31 PM
cargusjoh's Avatar
cargusjoh
Thanks for all the replies! Looks like I can get even wear at many pressures. In my previous car I got center band wear due to too much pressure trying to avoid that here. Again, thanks!
Old Aug 10, 2015 | 12:31 AM
yesti's Avatar
yesti
Pressure changes about 1 psi per 10 degrees of temperature change so take that into consideration as well.
Old Aug 10, 2015 | 07:06 AM
cargusjoh's Avatar
cargusjoh
We just encountered the temp drop Sunday. We were at MINIs in the mountains (our MINI5280 club event, was great!) and after the cold 44F night all our Countryman tires had low pressure. That cleared up after driving a short bit. Nice to know the rate of drop, never did before , thanks!
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
JamJam43087
Aug 16, 2015 02:02 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
nomar116
Aug 9, 2015 09:42 AM
