R55 How to Remove the Roller Shade on the Panarama Roof
Old Mar 8, 2015 | 08:41 PM
grussell's Avatar
grussell
If you want to remove and/or replace the Roller Shad in your sunroof if is very easy to do.
1)Tilt the rear of your sunroof up.
2)Remove the six T27 Torx screws from the glass panel (Three on each side).
3)Lay the glass panel somewhere safe.
4)Look at each end of the Roller Shade and you will see a plastic piece with 2 squares. Using a small flat screw driver slowly work the plastic piece up on each side and then pull the Roller Shade assembly out. (See Photos)
When you re-install the glass panel do not tighten the screws all of the way. Once all six screws are in loosely, close the sunroof. Then you can push up or down any area to get it flush with the roof. Before tightening the screws after aligning the panel push it forward into the seal. This will make sure you do not get wind noise.
From start to finish this should take 30-45 minutes.
Attached Thumbnails How to Remove the Roller Shade on the Panarama Roof-roller.jpg   How to Remove the Roller Shade on the Panarama Roof-roller1.jpg   How to Remove the Roller Shade on the Panarama Roof-roller2.jpg
Old Mar 9, 2015 | 01:38 PM
bbailey_33's Avatar
bbailey_33
awesome, thanks
Mine are coming loose from frame, any part numbers for replacements ?
Old Mar 9, 2015 | 09:36 PM
grussell's Avatar
grussell
Originally Posted by bbailey_33
awesome, thanks
You can find most part numbers by going to www.realoem.com. If you have the last 7 digits of your vin the system will be most accurate. Here is the information for the roller shades I pulled from the site.
Attached Thumbnails How to Remove the Roller Shade on the Panarama Roof-capture.jpg
Getrieben
Aug 15, 2015 09:09 PM
Aug 12, 2015 01:24 PM
bctf1
Aug 6, 2015 12:55 PM
