North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   R55 :: Clubman Talk (2008+) (https://www.northamericanmotoring.com/forums/r55-clubman-talk-2008-168/)
-   -   R55 This don't look right to me. (https://www.northamericanmotoring.com/forums/r55-clubman-talk-2008/280795-this-dont-look-right-to-me.html)
Avro Dec 5, 2014 07:06 PM
Last night I picked up my 2011 Mini Cooper Clubman. Tonight i noticed something very odd and possibly wrong. A friend told me I only had one reverse light (it just passed the safety 2 days ago). On closer inspection i saw that only the right side tail light had a clear lens for a back up light. The left lens is all red. Is this a quirky thing with the Mini or should I talk with the dealer?
Avro
cn555ic Dec 5, 2014 07:20 PM
Yes. It's normal.
Avro Dec 5, 2014 07:37 PM
Thanks.
Jayoni Dec 5, 2014 07:42 PM
Clubbie only has one reverse light.
broncobuddha Dec 6, 2014 12:05 PM
Yep, normal.
Weird to me though. However, if you look at both your rear lights, you'll see that the driver's side does have a clear/white reverse light, its just that the lens on that side has red covering it.
I believe you can buy an aftermarket lens that has that portion removed so you have two reverse lights.
14R55S Dec 6, 2014 12:59 PM
I don't spend much time in reverse so it doesn't bother me at bit.
MINI_42 Dec 6, 2014 01:09 PM
There's a how to on here somewhere about modifying the other one so you have 2 reverse lights...which is nice at night to give you extra light out back.
kmac17 Dec 6, 2014 08:45 PM
It's a rear fog light
The left lower tail light is used as the rear fog light. This is a safety requirement in the EU. It's a red light that is the same brightness as brake lights but stays on full time, when switched on. That empty slot by the gear shift is where the switch would be. The it's snowing or very foggy it makes you visible from the rear. Mini didn't spend the money to make two different sets of tail lights. So we US spec cars have everything but the switch and some programming.
There are also instructions on how to get it functional in the U.S. spec car, if you want to go that route.
Cheers.
MaxfieldMini Dec 7, 2014 06:31 AM
Following our Classic Mini Ideals, you could mount a full sized driving light on the back / on either one of the "barn doors" and bingo....lots of light. I love my classic, but I love my Clubman and the unique and tasteful rear quarters so I don't think I will go that route either.
TVPostSound Dec 7, 2014 08:35 AM
Buy a passenger side UK reverse lens, Left) wire it up.
