Front and Rear Fog Lights?
Recently got an 2012 Clubman and noticed one front fog light and one rear fog light needs to be replaced. I see that the front uses "H8" and not sure about the rear fog light. What bulb is the replacement?
What are the steps to replace the front and the rear fog light. Search didn't come back with anything and any help is greatly appreciated! |
Originally Posted by richie6
(Post 3967580)
Bulb replacement instructions are in the Owner's Manual. If you don't have a copy, download a pdf from here. |
Originally Posted by rkw
(Post 3967609)
The Clubman has only one rear fog light. It is on the drivers side (none on the passenger side).
Thanx much! |
Yep H8 for the front Fog Light ( lower Light on the fog light housing ).
http://www.ecstuning.com/News/MINI_R55_R56_R57_Ziza_Front_Fog_Lights_2007_2008_2 009_2010_2011_2012_2013_2014/ http://c1521972.r72.cf0.rackcdn.com/...5812_large.jpg And the rear 2011+ rear fog light is in the left hand side ( driver side ) taillight. They have the newer style taillights. ( LCI+). The passenger side is the same bulb for the back up light ( but has clear lens ) Its a P21 Bulb Clear . 6321716079 http://www.ecstuning.com/Search/SiteSearch/63217160790/ http://c1552172.r72.cf0.rackcdn.com/297533_x600.jpg That link above rkw linked , go to your 2012 Clubman and a diagram half way down through the manual show the removal. For the rear fog light, it has to have the toggle switch and be activated. Unless ordered. I believe they all have the bulbs there but need the switch and then MINI to turn it on in the computer. Thanks |
