R55 Way too much brake dust
Old Dec 30, 2013 | 05:40 AM
1yesfan's Avatar
1yesfan
I have an 09 Clubman. 68k. The brake pads seem to me to be putting off WAAAAAAAAAY too much brake dust. I could clean the rims once a week easily. I checked the pads and the dealer has also, they have plenty of pad on them, that said when I hit the brakes you can hear them making a pad rubbing noise. It is not a metal on metal noise but like a soft sound when the brakes are applied. All most like the pads are soft and they just make noise when engaged. The rotors are fine.
What would be a good pad that would put out the least dust?
Old Dec 30, 2013 | 05:57 AM
gnuse's Avatar
gnuse
I noticed the same with my car and installed Akebono pads. I was a bit skeptical about dustless claims, but I must admit they have nice feel, bite, and virtually no dust. I mean NO dust.
Old Dec 30, 2013 | 07:35 AM
Helix13mini's Avatar
Helix13mini
Just about any aftermarket pad will produce less dust than the factory pads. There are some pads that claim to be 'dustless' which is a bit of a stretch, but generally, they produce the least dust. EBC Greens are a good example of those. We do sell them with just a little reservation: they have on occasion de-laminated under hard use (the pad material falls off the backing plate). I prefer the HPS pads from Hawk. They perform extremely well and are much lower dust than stock.
Old Dec 30, 2013 | 08:47 AM
bmwr606's Avatar
bmwr606
i have an 03/2012 build cms all4 and the oem pads produce less dust than any other vehicle i have owned
mini must have changed suppliers at some point
maybe you could convince your dealer to a "good will" change to the current pads
scott
Old Dec 30, 2013 | 09:28 AM
sarahminilover's Avatar
sarahminilover
I have an 09 mini R56 I noticed the same thing I was cleaning my rims every week I used aftermarket wagner thermo quiet pads and noticed a lot less brake dust. they were only like 50$ so I was happy with the results and I'm impressed with the stopping power. Over all I'm please the only thing is that they don't come with the pad sensor so I had to get that separately. Motor On :D
Old Dec 30, 2013 | 09:29 AM
sarahminilover
god that brake dust tho
Old Jan 1, 2014 | 06:04 AM
Hawkeye's Avatar
Hawkeye
I have a 2009 Clubby on which I installed Carbo Tech 1521s at 3K miles...over the last 33K miles, there has been a significant reduction in brake dust. Before I bought new Michelin AS tires, I pulled each wheel, cleaned the inside of the wheels and applied Rain X...makes it much easier to remove dust & other grime.
Old Jan 1, 2014 | 06:48 AM
danjreed's Avatar
danjreed
Stock pads are wicked soft (decent brake power, quiet, easy on rotors).. trade off is the dust.
When these are smoked.. I plan to go with a set of Hawk pads.
I've used the EBC Green Stuffs on other cars, didn't know about the delamination issue. They put out a very light, tan dust.
My buddy who was a tech at the local Mini dealer recommended ordering my car with black wheels because of the crazy brake dust. I was glad I did.
Old Jan 1, 2014 | 09:43 AM
flredmini's Avatar
flredmini
I put factory white wheels on my 2011 MCS, and the brake dust from the factory pads was bad. I switched to ceramic pads and the brake dust was reduced to an acceptable level, and brake performance has been fine.
Old Jan 3, 2014 | 12:05 PM
+1 on The EBC or Hawk pads. Some of the akebono pads have less dust. We have them all right here:
We have the pads here for your 2009 MINI Clubman S :
http://www.ecstuning.com/Mini-2009-Cooper-R55-S_Clubman-Coupe-L4_1.6L_N14B16A/Braking/Pads/
BernieCoop
Sep 10, 2021 03:15 AM
Sep 10, 2015 10:52 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
squawSkiBum
Sep 2, 2015 09:56 PM
