R55 Baby Kito's Clubbie timeline
#76
MINI got a feature on an online site Show Stoppers. Check it out guys and let me know what you think!
Show Stoppers
Show Stoppers
#77
My goal is to get as close to that as possible. Nothing more. It's a FWD car so it's not a racecar. I have a new turbo on the way from FrankenTurbo and will shortly be installing a water/meth kit. Obviously with corresponding mods such as straight pipe from the turbo back, FMIC, mounts all around, custom RMW tune etc. if need be ill do more modding. Thanks for your input.
#78
#79
#80
I apologize I'm not trying to argue my point I just don't see the need to do as much as you think I do. My turbo is basically a ko3 case with ko4 internals. It'll push more but nothing crazy. Meth will give power for sure, but won't be over the top especially with its assists to the motor temp wise. The front mount is always a huge help on turboed cars and same with the exhaust and tune. So maybe it'll do 300 at he crank. Maybe 285 at the crank. That motor can handle it. 300+ yes you'll start seeing issues greatly. But I'm also not taking the car to the track and redlining it daily. I mean it's on air, meant to be as low to the ground as possible. The power thing is just for fun on the side. I truly don't believe it'll be an issue.
#81
January Update
The new snail is on it's way as well as new gaskets for the intake manifold for when I clean out the ports. I also ordered a set of Alta V2 front end links so I can FINALLY install my sway bar... Car can't put all it's power down smoothly without it and it's just awful. Pics will follow later this week when I receive the goods.
#82
January Update
#83
#84
UPDATE!
Just recieved the IM gaskets and TB gasket for when I clean my intake valves here soon. Also got my Alta end links. They are really nice looking and the qaulity looks really good. Ill post pictures with the DSLR here soon. Also got some one step colder plugs. Turbo will be here tomorrow!
#87
#89
Hmmm yeah I wonder. Ill look into it though thanks!
I would like input on someone to tune my car. I need to use them from the baseline through the install and with corresponding mods all the way up to meth. ALTA and RMW are out. Any other suggestions?
#90
#91
#93
I looked at that but I don't think they can run off my dyno to make a specific tune, and they also can't tune for meth. Which is very close after install.
#95
#96
#97
I actually didn't build the box. I bought it off ebay for really cheap. It's just a shallow box for the shallow mount series subs. So I have a 10" Rockford. Fits perfectly on the in between shelf in the clubman since my air setup is in the spare tire well. I can get pics still if you want.
#100
Thanks sir! I just need to find a way to data log my car before I can start the install.....
